Results 1 to 10 of 10
Thread: Boosted e38 -- when do you enable PE?
    Dec 2012
    North Carolina
    119
    I've been fighting a very limited part throttle popping. I never seem to be recording when it happens. Tonight, it made me wonder if I have my parameters to enable PE too high (i.e. the popping is because it's too lean and not in PE). Would you mind sharing?
    MAP: 70 kPa
    MAP Hyst: 6 kPa
    Enable RPM: 2,000 RPM
    RPM Hyst: 20 RPM
    Hot PE TPS: 45% 0-2,000 RPM, 30% 2,500+ RPM
    PE Delay: 4,000 RPM
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by granatl View Post
    MAP: 70 kPa
    MAP Hyst: 6 kPa
    RPM Hyst: 20 RPM
    PE Delay: 4,000 RPM
    I have found that the newer OS's don't seem to offer (or at least I can't find it) you the Cold PE TPS setting that I have seen in the past. This allowed you to set the throttle to say 5-10% and let the MAP (load) dictate when the PE was to activate. It appears that the "hidden" cold throttle setting is like 40-45% (seems like 42%). The Hot PE is only for when engine temps reach 248F.... again this is an educated guess based on what I have read.
    Do need to see if the POP is fueling or you are into a very low timing area due to load and rpm. Also make sure you have tuned you VE at least from 4000 rpm and down. In the Blended mode, it is used to validate the MAF and again, I am not completely sure if the "richer of the two" would take precedence.
    Ed M
    [email protected]
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Set TPS enable to 5 and MAP enable to whatever you want. It'll go off MAP then.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    MAP: 70 kPa
    MAP Hyst: 6 kPa
    RPM Hyst: 20 RPM
    PE Delay: 4,000 RPM
    I would personally copy the stock ZL1 settings... which rely on TPS to enter PE... not MAP, since MAP is slow to respond... noticed this when I first got my Whipple on the 6 speed.. between shifts the PE was laggy when I had it enabling around 90 kPa. Aparently GM noticed the same problem so they enable PE based on TPS... ZL1 settings are seen in this pic.
    MAP: 15 kPa
    MAP Hyst: 6 kPa
    Enable RPM: 300 RPM
    RPM Hyst: 30 RPM
    Hot PE TPS: 18% around 2,000 RPM, 19% 2,500+ RPM
    PE Delay: 5,000 RPM, however I would cut this way back.
    ZL1 Wheels/Tires
    Dec 2012
    North Carolina
    119
    So far, so good. I didn't get to drive far on the ZL1 settings, but I did let it short shift and then gassed it w/o popping. Thanks for all the great info guys!
    Mar 2007
    Florida
    3,772
    Dave, even though there isn't the 2 TPS tables anymore, the Hot Throttle table will still command the TPS value below the Hot temp threshold? I use the same PE entry technique letting the load determine the need.
    Thanks,
    Ed M
    [email protected]
    Mar 2008
    St. Louis, MO
    4,862
    Quote Originally Posted by mowton View Post
    Thanks,
    Ed M
    There's no hidden table on Gen IV. Doing what I said sets it to boost activated (unless you're able to somehow make boost with only 5% effective throttle area).
    Mar 2007
    Florida
    3,772
    Dave,
    My question/observation was based on the HPTuners transition from Gen III to IV removed the COLD TPS table and you were left with one titled HOT. Most of the tuning I do is with the other software and it doesn't differentiate between cold or hot and the above PE scheme works fine.
    Another question is though the TPS% do not reflect the actual TP% PID being logged. I assume that the percentage in the table is the delta value from the idle value which would be like 22% or so. I normally set that value to 8%.
    Thank you for the clarification.
    Ed M
    [email protected]
    Mar 2008
    St. Louis, MO
    4,862
    Dave,
    Ed M
    Maybe it is mislabeled on Gen IV, but there's only one functioning.
    I think Chris said the values in that table are the effective open area minus idle contribution. It doesn't correlate to any PID directly. The % values in the scanner correspond to percentage of angle and not area.
    Mar 2006
    DFW, Tx
    156
    Quote Originally Posted by 10_SS View Post
    FWIW, on my ZL1 I did this.....
    ...and have no more issues with not being in PE when under boost.
    2013 ZL1 A6
