Results 1 to 8 of 8
Thread: A4 to M6 Conversion speedo error
    Mar 2004
    Summerville, SC
    20
    I just did an A4 to M6 conversion on my 98 Z28. Now my speedometer is way off; like showing 20 mph @ actual 50 mph. I downloaded a stock '98 M6 bin file and copied my tune over to it. Then I reflashed the computer, but it is still off. I have 26" tires with 3.73 gears
    Any ideas?
    Proud owner of a \'98 Z-28. Just another Red Headed Step Child!
    28,303
    what version are you using that its saving in bin format still? I checked the calculations on a 98 hpt file I had and the vss/mile, vss/rev-trans, & trans revs/mile were all completely different then what your bin says...Maybe there was a bug in the version your using and thats why its fubard.
    I got:
    48896
    17.0000
    837.3632
    compared to your
    115140
    40.0000
    2878.5936
    Mar 2004
    Summerville, SC
    20
    I am using 2.16 I just saved it as a bin file. All I did was change the extension from .hpt to .bin. I will include the corrected one this time
    I know the numbers look a little out of whack
    28,303
    one way or the other i think your vss stuff is off which is why your file isnt working correctly.
    Mar 2004
    Summerville, SC
    20
    I cleared out the numbers and recalculated. I came up with:
    49176
    17.000
    842.1679
    I will reflash and see what happens
    28,303
    sounds much better
    Mar 2004
    Summerville, SC
    20
    Quote Originally Posted by foff667
    sounds much better
    Thanks for your help.
    That did it. It is reading correctly now. If I can get my idle working right, I will be good to go.
    28,303
    no problem
