Page 3 of 64 FirstFirst 12345671353 ... LastLast
Results 41 to 60 of 1261
Thread: VCM Scanner 2.25 Beta Now Available
  1. #41
    Feb 2006
    Rancho Santa Margarita, CA
    905
    I've been asking support to get the new scanner 2.25 since Saturday, thinking it was a separate file. if you see the download link with the 2.25 in your personal link in support center, download that and install it, once you're done, go to the Hptuner folder /Beta, and scanner.exe will be there.
  2. #42
    Feb 2006
    Canada
    1,963
    I already like the table view more, the table view has always bothered me...lol, sorry... as for the histo table set-up, looks great. Looks fresh and up to date guys!! When they are standing over your shoulder watching you this will look much better than the .24. Clean, profesional look to it. I give it a yes
    2000 Trans Am WS6
  3. #43
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by bluegoat06 View Post
    2.25 the beta.. I thought that was pretty well explained
    It adds shortcuts to your start menu.. so no need to do all that
    And, by default, it opens .hpt / .hpl files
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  4. #44
    Sep 2013
    44
    Is there a pid to log afr using the o2 sensors? If so, would that be a reliable source for wot fuel, or should I just keep with an external wideband?
  5. #45
    Sep 2002
    Chicago, IL
    6,397
    All depends on what vehicle you're talking about.
    We got this guy Not Sure, ...
  6. #46
    Sep 2013
    44
    Sorry its a 2014 f150 5.0
  7. #47
    Sep 2002
    Chicago, IL
    6,397
    Not sure if that vehicle has lambda/wide band sensors, or narrow band sensors.
  8. #48
    Sep 2013
    44
    They are wideband sensors. Same ones the 5.0 mustang uses. There are multiple pids that mention afr but nothing specific.
  9. #49
    Sep 2002
    Chicago, IL
    6,397
    have you tried to log them? The SAE afr pids should work.
  10. #50
    13,606
    Someone should toss up some screen shots, I'd love to see what it's like. Don't need to download as I dont have a ford/dodge.
  11. #51
    Aug 2009
    Calibrating
    3,378
    How is the logging speed? Can I log more than 24 bytes now? E92 GM ECU needs this to tune correctly.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  12. #52
    Sep 2002
    Chicago, IL
    6,397
    Yes. The amount of parameters you can log on any vehicle is limited only to the total number of supported parameters.
  13. #53
    Sep 2013
    44
    Quote Originally Posted by Keith@HPTuners View Post
    I'll give it a try tonite. I've been having trouble with the scanner kicking me off after I stop recording. An error would pop up and ask if I wanted to report to hptuners. But ill give it another try tonite. Thanks!
  14. #54
    Apr 2014
    706
    I attempted to log a 2005 Dodge Neon SRT-4 last night, but the only parameter that would log was TPS.
    Guessing that it's simply a matter of waiting on getting all the parameters added into the new scanner before we'll have much more than that?
    Seemed kind of strange that it didn't at least have the same set of parameters available for logging that the 2.24 scanner has.
  15. #55
    Advanced Tuner midevil1's Avatar
    Feb 2009
    TX
    365
    I keep getting a VCM not found. Make sure key in RUN position and cable is connected. This is what is happening since I downloaded the latest 2.25 version. Scanner will not connect...
    2023 Ford Edge ST
    2020 Ford F150 King Ranch 5.0
  16. #56
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by B00STJUNKY View Post
    Should support many SAE parameters, and all the parameters 2.24 supports as well.
  17. #57
    Mar 2015
    12
    I have emailed requesting access to the BETA and have not gotten the access yet.
  18. #58
    Feb 2013
    41
    Quote Originally Posted by nstag8r View Post
    same here
  19. #59
    Sep 2012
    5
    I have the beta.. and when I went to update my tune with it, it said the OS wasn't the proper version and needed to be upgraded. So, I did a write entire. It failed and I lost all communication with my VCM. Towed the car to a GM dealership and their Tech 2 wasn't able to communicate with it either. Basically my VCM is toast. Luckily I had a friend who has a spare one.
    My question is... I've updated the configs on my car many many times without fail. I've done one write entire prior to this one and it went fine. Did I screw up in trusting the Beta to complete a write entire? Did I do something wrong or was it the software?
    This was on a 2007 Saturn Sky Redline. (LNF)
  20. #60
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Is there a keyboard shortcut to navigate the histograms? I.e. in 2.24 you can use the 1 through 0 keys to flip through the different histograms. That isn't working on the beta.
    Can something like this be added? Pretty please?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
