Hello, would you know if the latest beta software has real time tuning for the virtual VE table? Im thinking of switching to EFI live but I got quite a few HP tuner credits left...
There is no real time tuning for the PCM's with virtual VE. Not with HPTuners or EFILive.
2023 Durango Hellcat
So when is projected ETA on having this fully functional so we can actually do this in program and not have two versions of HPT open (one for vehicle, another to use as a VE editing table with smoothing functions etc) AND bluecats software open? EXTREMELY tedious currently
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
I have now downloaded the beta. I like the implementation and especially the ability to see zone numbers. Pretty cool. I still will not be able to use it without custom axis though. As mentioned custom RPM and MAP axis is a must for me. This is logical to me as well because no matter the engine's aspiration and redline you can customize the table to fit the need and have better resolution by only using a scale that has what you need. For me that is 0-6400rpm and 15-150kPa.
Thanks for the hard work!
+1......watching this closely for the new release!
Any updates on the full release for this? I like where it is going but I need the custom axes as well (blown LS2 so I need more range on the MAP scale).
Any updates on this?
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
how do I get a copy of this? I have emailed but no response
Apparently it doesn't work it just gives you something pretty to look at.
Also I've noticed for whatever reason bluecats tool doesn't work with it. Read the car with the beta version and it wouldn't work, I also couldn't open that read in the non-beta version so I had to re-read the car lol Oh well looks cool can't wait til it works.
Maybe my beta version is old but whatever![]()
So pretty much better to use blue cats tool for now?
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
sooo pretty much like a stripper twin of Kate upton..... just a tease. I still would like to get a copy of 2.25 to look at.
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
I've noticed a pretty big difference in the VE numbers generated from the same equations between this and Bluecat's tool. If I could copy out of the table I could figure out exactly how much of a difference, but I don't feel like manually entering 1024 numbers in a spreadsheet.
Also, in the end this will just be a nicer way to edit VVE equations from within the editor correct? To get a real VE table we would still need to upgrade to the 2.5bar OS right?
Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Today's beta has a functional "Virtual VE" -> Coefficient generator.
The algorithm we use is different than bluecats and can use some testing.
We're still cleaning up the copy/paste/undo functionality of the Virtual VE form.
We got this guy Not Sure, ...
