Here you can see a few things. Engine RPM is a broadcast parameter. MAF Period is a DMR. Spark Advance is a non-SAE PID. More coming soon.
Eric Brooks
HP Tuners, LLC
That's awesome!
Nice. It will be nice to be able to dial in the MAF curve using the 2.25 scanner.
Beautiful daughter, by the way!
What's the difference between the type of the parameter?
http://www.dsxtuning.com
Just say no to bull s***.
The method in which they are requested, or in the case of the broadcasted RPM, we are just listening for it, so there is no overhead of having to request something.
The DMR and Enhanced PIDs are very fast and there are a lot of things you cannot log unless you have DMR support.
Eric Brooks
HP Tuners, LLC
Awesome... Your helpers smile at the end was priceless!
We all know she's actually the one programming the software...she just can't reach the pedals to test it yet!!!
2023 Durango Hellcat
So what's "DMR"?
Can't wait for this to get out so logging more of the ford stuff comes easier.
https://www.facebook.com/tuningbyshanehinds
[email protected]
2009 G8 GT [email protected] 1.60 - Sold
2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
2013 CTSV wagon 9.21@151
2015 C7Z bolt ons 10.0
Just when I've all but given up on 2.25 scanner. Why do you have wb lambda 1...makes sense b1, but then the other is wb lambda 5?
"I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
That is an SAE PID. I have to look into it. I didn't add that. SAE PIDs are universal so its just what the scanner pids up.
Look here - http://en.wikipedia.org/wiki/OBD-II_PIDs
SAE PID 24 and 28 is what the scanner is picking up on. Just how Ford chose to implement it.
I'll be adding in the actual Ford Enhanced WB PID pretty soon, and it will be high speed.
Eric Brooks
HP Tuners, LLC
Nice work! I can now read MAF Hz and KR, thank you!
