[email protected]
Here is the log with MAP and STIT
2006 Escalade LMM Duramax Tuned
2000 S10 Twin Turbo 6.0L
56 GMC 100 Status Unknown
Cancel that
Here is the file that is loaded and I made a huge adjustment last night to the VE which is allowing it to idle. Also here is the log from just now idleing only, same log name as other but different.
That can't be right for the VE...way too high. But lets go with it for now.
Using the set screw, open the blade until you have an IAC position count of 50-70. Turn slowly and let the PCM catch up. Shut off engine, disconnect IAC/TPS connector from Throttlebody, turn key on (don't start) for 30 seconds. Then key off and plug IAC/TPS connector back in. This should reset your TPS back to 0% at closed throttle and we will see what the voltage is. I think you will be alright. Want to see it below .75 volts.
Then we will see what the STIT are during idle. They will tell you whether you need to raise or lower your Base Running Airflow values. As it is hot now, run the scan and you can adjust the temp level you are at. Use the delta percentage from what is was and what you changed it to and apply that to all the other temperature cells in the PN row.
The VE is going to then be looked at...it will be way to rich.
Ed M
[email protected]
Up to temp or does not matter? I know the VE is ridiculous high but funny AFR reads 13.8-15 after adjusting to those numbers.
[email protected]
GM 12615136 is a good choice.
Ed M
[email protected]
12623671 AC Delco
Cranked the screw all the way, slowly, after about half a turn the IAC dropped to 150ish then wouldn't change much from there. Idle dropped way out then slowly with each turn came back.
[email protected]
Disconnected, waited, re-connected and ran log. IAC jumped up 30!!
Try this ...366.70 and 33.33. With Key on and engine off (KOEO) you should see your local baro which down here will be close to 100 kPa or so.
Ed M
[email protected]
What the ****, really! So should I just apply the three bar OS and go from there?
Not sure where the 366.7 and 33.33 go.
Slow down....you have to get the map straightened out first......:-)
Ed M
[email protected]
[email protected]
Never mind found that
[email protected]
Heading out to walk the dog BRB
Ed M
[email protected]
