Little help on injectors. 15 gt, got 09 gt500 injectors (47#) and need some help on what to change to make it work. Thanks
Copy everything from the Roush tune in Fuel>General>Injector Control>Flow Rate.
Not the same injector as OEM Roush. Calibration data for what you have is here: https://fordperformanceracingparts.c...-9593-g302.pdf
Will the shorter injector still fit?
They are about 12MM shorter. I don't know what kind of intake manifold, rails, etc, you have. If it is for the stock coyote length injectors, you'd need some of the spacer kits available in the aftermarket. I'd rather use the longer injectors if that is what your particular hardware is made for though.
Its all the stock 15 stuff.
