Any hope of AFM disable functionality for Hemi applications?
I am using an old log from the old scanner.. 08-10 cobat turbo, spark tables are load vs rpm.. It wont load the load row properly with pids selected.
Okay last question and I'll let you deal to more important matters...
What about Real Time Tuning. When is that going to be implemented into the new scanner. This is one of the main reasons I didn't use the beta version that often was due to no RTT for the earlier applications that support it.
James Short - [email protected]
Located in Central Kentucky
ShorTuning
I just happened to be about to tune my VE tables on my Camaro, and setting up the scanner seems to be pretty easy, but since it removed my 2.24, I'm having a hard time setting up my wideband AFR error histograms, finding the correct parameters for the AFR sensors is giving me issues to get it like I want it.
2012 Camaro SS/RS M6. TVS2300 w/rear OD cog drive and ported lower manifold, On top of a forged 416.
1999 GMC Sierra 2500. Stock 6.0L, LT headers, cat delete, and Airaid intake.
1965 Oldmobile Cutlass. 5.7L LS1/4L60E transplant in progress from 98 TransAm donor car.
Unless there arent as many pids allowed in the new scanner as there were in the old scanner.. I had the old scanner pid channels list completely full.
Very Cool!!!! Thanks!
I have load working properly on my LNF scanner layout. See if these help you
LNF Trial 2.Channels.xml
LNF Scanner Trial.Layout.xml
They are a work in progress, but I believe load is functioning as it used to.
Will this new version allow me to install another A6 trans in my Vette and have the ECM accept the changed operating system of the different trans, or do I still need the dealer to do this?
I had a version of the 2.25 beta that allowed me to turn on reverse lockout for my T-56 but I don't see it in 3.0. Is there any way to get that option added back?
Edit....wrong laptop. My bad
