James Short - [email protected]
Located in Central Kentucky
ShorTuning
You are quite right about that--I misunderstood the question
No.
3.2 seems to always open as a small window, while other versions used to open as I last closed them. Is that for everyone or is it something on my end. Just wondering.
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
If you're using an older version side by side, your settings will not work as expected.
3.2 should remember your size and location correctly.
We got this guy Not Sure, ...
Just played with it a little further.
I am not running any older versions. Whats strange is it opens about 8"x8" and will reopen in the same place I close it last. If I expand it to full screen and then close it, it reopens full screen. It will only do those 2 things. If I use half the screen for example, and then close it, it opens as a small window again. It wont remember unless its full screen. All previous versions opened exactly as I closed them, which for my is about 3/4 of the screen used.
Alky Control Meth,
ARH 1 7/8 headers,
Are you using a multi monitor display, or anything unique to your setup?
Alky Control Meth,
ARH 1 7/8 headers,
So I am also tuning a 2015 C7 LT1 stroker with a supercharger and it too will not get into boost with a failed MAF.
So the two variables here are 2014 (which worked) vs 2015+ or something to do with 2.2x vs 3.x
Still hitting my head on the wall here, if there is any solution it would be appreciated.
I think if you right click on your icon ,propertys you have the choich of what size window it opens in.
06MonteSS
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, Custom paint-matched Bowtie emblems, Custom painted SS emblems, BMR strut tower brace, CAI - Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Bo White Ported/Polished throttle body, Custom DiabLew Tune
We're looking to put that fix into 3.4
Will this update support 2016 Chevrolet Cruze 1.4T? A coworker has a loaner and thought I'd copy the file with v3.0 and it would not recognize anything.
I can try again Thursday or Friday if this current update will work. If not can I help getting a copy to someone?
3.2.20, E40, 2005 vette: Alcohol percent is not displaying in the scanner channel list. The channel is there but the value is blank. Thought it may be a problem with my ethanol sensor retrofit but 2.24 displays it properly.
Bill Winters
Out of the LSx tuning game
Updated to latest build, 3.2.25 with same behavior.
Bill Winters
Did you use a 2.24 config or add that channel In 3.2? I know it works in mine, I'll post my channel list in a bit to see if it works then
No my channel list in 3.2 was initially created in 3.0 and was working then. Attached is the channel xml
Bill Winters
Also if I open an old 3.0 log in 3.2 it displays properly.
Bill Winters
