Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 61
Thread: caliber srt4 tuners???
  1. #41
    Sep 2016
    49
    max map voltage in 4.9
    tune says max kpa is 217......... but i can input another value if i want.
  2. #42
    Sep 2016
    49
    also cant log VE
  3. #43
    May 2015
    1,908
    would be good to post the tune.
  4. #44
    Apr 2014
    706
    Quote Originally Posted by bosstin87 View Post
    Sounds screwy. Like 06300CSRT8 mentioned, post your tune file. I don't see anywhere in a stock Caliber SRT-4 tune file where it is set to 217 kPa as a limit. Was this changed to 217 kPa by you, or someone else? And why?
  5. #45
    Sep 2016
    49
    BOOSTJUNKY, can u post the stock caliber srt file, id like to take a look
  6. #46
    Apr 2014
    706
    08_CSRT-4_Stock-Cal.hpt
  7. #47
    Sep 2016
    49
    Thanx,
  8. #48
    Oct 2015
    Antelope Valley, Ca
    13
    You want a e85 tune for the csrt4 so u can have a base tune to go off of? im currently running that tune hitting 24psi, 450+whp on built head stock block
  9. #49
    Sep 2016
    49
    yes that would be amazing, pm'd
  10. #50
    Tuner in Training Awd1990tsi's Avatar
    Feb 2016
    Toledo, Ohio
    18
    Quote Originally Posted by mmrodriguezjr2012 View Post
    also interested in that if you don't mind, been chasing my tail with my car for a long time now. Mostly with throttle pull and can't figure out what the heck the deal is.
    Also bosstin87, did you start with a stock PCM or did it have a canned tune on it before? I know my stock PCM will show me however much boost I'm really showing on the gauge in the data log, where the non stock one will only show up to ~17psi in a data log
  11. #51
    Tuner in Training MassCaliber's Avatar
    Massachusetts
    19
    I'd like to join the fun here, I just got hptuners for my caliber and so far I seem a tad off. Have you guys messed with the Power Enrichment at all or are you going straight to the VE table? Also when I was messing with the VE table and making minor adjustments, when I went to try it out my AF was incredibly lean under WOT at lower rpms so I backed out of it. The scanner doesn't record the AF but I do have an AF gauge hooked up. It stayed in the 14's at WOT around 2k rpm so I didn't stay in it and see if it dipped. Can't afford a motor.
  12. #52
    Nov 2015
    St. Louis MO
    188
    MassCaliber post yiur tune. A simple thing to do is make sure wot delay is off, and also you set PE to 1 solid number then adjust VE for fueling
  13. #53
    Massachusetts
    19
    Current tune3.hpt
    My current "tune"
  14. #54
    Massachusetts
    19
    Where do you find the WOT delay?
  15. #55
    Nov 2015
    St. Louis MO
    188
    Under Airflow>electronic throttle>pedal wot. Yours is zero so no worries.
  16. #56
    Massachusetts
    19
    I just went and tested that file. The car was actually slower than stock...any hints or tips on what I may be doing wrong?
  17. #57
    Massachusetts
    19
    af is a strong 10.9 11.0 so my assumption is the power loss is from the enrichment of the fuel, but after messing with the VE table at WOT it hasn't gotten any different.
  18. #58
    Massachusetts
    19
    I think I got it now, after messing with it all week and doing small steps. Boost is up around 18, fueling is on point through the wideband and she's a lot louder now both cruising and wide open. I just have to run some logs and make minor changes from here.
  19. #59
    Tuner in Training GeorgeGG's Avatar
    Florida
    24
    hello
    is there any way to avoid that 217kpa limit?
    i have upgraded turbocharger on Caliber SRT and cant run full throttle above 217kpa
    please step in experienced ppl
    sorry for offtopic.
  20. #60
    Massachusetts
    19
    Ok so I revised the tune, got a lot of help from a couple people but when I ran a log there was almost no timing. I'm stumped, I can't figure it out. But I also can't read knock on the scanner, quite pathetic that the car won't tell you if it's knocking. Anyway,MS1C1.5_3.hpttest.hpl here is the tune and the log (3rd-most of 4th). If anyone can shed some light on what might be up please PM me. Thanks.
