I went over the files and replaced those awful parameters from the original tune. The idle fluctuates
alot once I depress the accelerator and ease it up to around 1200 to 1400 rpms it levels out and runs great, if I let off of the accelerator it goes back into the loping and sometimes dies. Although there was one instance where after holding the engine around 1400 rpms for a little while I let off of the accelerator and it purred while idling, then probably 30 seconds later it started loping, softly at first then it just went apesh*t with the extreme loping again. I was wondering if in the instance that it was idling so well if it went into closed loop or something?
Also, I should mention that I absolutely
CANNOT get the ECM to learn the crankshaft position variation. Ive read and read the process and tried it standing on my head, and it just wont do it.
Help?
