Results 1 to 13 of 13
Thread: Sudden drop in G/Cyl for no reason
    Apr 2016
    19
    Hey Guys,
    Having some issues on a 2010 silverado, turbo, running SD.
    Occasionally, while driving (any load) it will feel like it shuts off. Finally got a log of it (Attached, see the end , 02:32:32.749) you can see the g/cyl drop out all of a sudden, timing goes up, fuel shuts off, then it comes back. But MAP doesn't change, and no real hickup in RPM (until after it shuts fuel off), and there is no MAF at all. Nothing else I can see as far as sensors is picking anything up. Any idea what would cause this, or what all sensors are calculated in the G/cyl copulation?
    oop.hpl
    It's only for a split fraction of a second, but you can feel it REALLY bad when driving. And always right after the knock and burst seem to act up for a few more fractions of a second.
    Standard OS? I can?t view the log right now but only time ive experienced the same was on a SD E38 with MAF removed and never got to the bottom of it because the car was sold. My next plan was to swap to EnhOS as I chased it as a APP issue for a while.
    Feb 2015
    Perth, Australia
    972
    post file.
    you can see PCM is asking for it as the inj pulsewidth falls away
    Apr 2016
    19
    Quote Originally Posted by lukearmstrong1990 View Post
    post file.
    The File is attached below.
    Apr 2016
    19
    We are on a 2 Bar OS.
    Apr 2016
    19
    Bump
    Jan 2004
    Perth - Western Australia
    299
    You ever find what was causing it? Have come across a car that is doing this exact thing. Inj PW will drop to nothing. which causes a knock event when injector comes back on.
    Car is auto & SD with small cam, exhaust only. had same os car's with identical mods not have this happen. so im a bit perplexed on why this is occurring.
    kinda feels like ecu is triggering a knock event to check sensors are there. since the engine was pulled for cam work. i don't know if it had this issue before.
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,110
    Quote Originally Posted by Tre-Cool View Post
    Are you in SD? If so its corruption of the MAP^2 VVE coefficient. It can spike the calc'd VVE to the maximum or minimum.
    https://forum.hptuners.com/showthrea...ittent-Stumble
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Jan 2004
    299
    Yeah. Cheers for that. Probably my fault as i copied the coefficients over from another tune, when i've never done that before. was in a hurry. typically i copy the VE map only, then regenerate the coeffecients.
    Doh.
    Tuning Addict
    10,887
    OP's file doesn't even have the right injector data (along with many many other problems, like PE never comes in ever).
    Aug 2021
    1,110
    Doh.
    No that is not all the situation. It is a defect with the OS when you go into SD. If you have not failed the MAF then this is NOT your issue.
    MAF Assistant
    EOIT Assistant
    Jan 2004
    299
    Im not using HPT for tuning.
    The tune file i used as the base had the maf still enabled. I Typically dial in the VVE, then re-enable the maf. Both cars have same mods, except this one is SD only. which would explain why SD-MAF car never had this issue.
    Aug 2021
    1,110
    HPT or brand E, or whatever, it doesn't matter. The issue is in the ECM for SD.
    MAF Assistant
    EOIT Assistant
