Results 1 to 14 of 14
Thread: where trans tq management coming from?
    Baltimore, Md
    1,213
    Pretty sure I wiped everything out but missing something
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Feb 2015
    Perth, Australia
    974
    its trans tq management.
    log shows less torque than your max allowed in engine tm vs gear.
    I would try disabling fast torque exit and max torque values
    max out all max torque vs gear under torque limit vs RPM
    mas out trans input torque
    Baltimore, Md
    1,213
    Quote Originally Posted by lukearmstrong1990 View Post
    Yes log shows less torque than limits so it shouldnt be limiting, and later revision had everything raised up and maxed out, still act same?
    Baltimore, Md
    1,213
    ideas?
    Aug 2008
    Chicago
    98
    Torque management, general, traction control, max torque is set to 400 ft lbs. Try raising that?
    2000 WS6 Trans Am LS3, Tick Performance Stage 2 cam, ARH 1 7/8" Headers, FLT Level 6 4L60e, Circle D 5c Launching on a 200K 10 Bolt
    2001 Camaro SS M6 Black on Black
    Feb 2015
    Perth, Australia
    974
    max out traction control torque values.
    max out max torque values for axles and prop shaft below trans input/output.
    appears its happening in kickdown. if that doesn't work must be something in the background u cant see send files to HP support
    or maybe some indepth trans data like shaft speeds, torques and slips may help if possible to log
    Baltimore, Md
    1,213
    I had that higher in previous revision, dont think it did anything though
    They basically were with values in the thousands?
    Dec 2015
    7
    Try this and it'll solved AM sure , GO TO YOUR Trans TQ Management , RETURN THE ABUSE MODE TO STOCK & HERE YOU GO
    GO TO YOUR PE TABLE & ZERO THE DELAY ...
    GO TO ENGINE DTC & RISE ALL OF MISFIRE TABLES, ITS LOOKS THAT YOUR RUN A TQ CONVERTER & THAT WELL HELPS THO ..
    Tuner in Training NicD's Avatar
    Dec 2005
    phoenix, az
    40
    Quote Originally Posted by NicD View Post
    Here you go.
    Man I was hoping to at least get a response since I posted up the fix.
    2016 C7 Z06 | 2017 ZL1 | 2009 C6 Z06 | 1994 GT - The LS-stang | 2010 Tahoe SSV
    Baltimore, Md
    1,213
    Where did you post up a fix?
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by GrannySShifting View Post
    Did you ever get this resolved? I'm dealing with this exact situation on the same year engine/trans combo in a swap situation. Cannot find the culprit.
    Jaime
    Baltimore, Md
    1,213
    I think it got it 99% squared up if this is the swap car Im thinking about. Email me [email protected]
    Feb 2006
    South Carolina
    1,525
    Not sure which car you might be thinking about, but I found the fix, if you are interested.
    https://forum.hptuners.com/showthrea...l=1#post434344
    Jaime
    Arizona
    562
    Quote Originally Posted by ElecTech View Post
    I found the fix, if you are interested.[/url]
    hope nicd could post up his info that seemed to disappear..
