Page 4 of 4 FirstFirst 1234
Results 61 to 75 of 75
Thread: 2018 Mustang dyno rev limit.
  1. #61
    Oct 2016
    Poland
    1,771
    Guys please stop bombarding me with pm's and emails - everything I know is in this thread.
    I tuned this trans they way I tune the 6R80. I still have one issue - WOT shift tuning does nothing for me.
  2. #62
    Jun 2015
    20
    Quote Originally Posted by kris5597 View Post
    Problem solved! It was the Element RPM Limit. Total increase is 10% over stock, 6 > 7 shift is now 7250 and almost 5600 OSS. I will continue to increase but this was a very successful evening. Now I am fine tuning my shift points up to that point, car is a rocket on ethanol.
    Kris
    Great job Kris!!! Thanks!! It's a lesson for me. Always read correctly the description!! Happy I was wrong and you were right !!!
    I probably would have found it but it may have taken days even weeks before I decide to try it lol. Especially since I was not hitting it at the drag strip with my 3.15 so it was not as painfull as those with a 3.55!!
    I should be good with my 15% increase. Will try it later!
    Thanks again to everybody !
    I hope it's solving almost everyone having the 6th gear issues!
  3. #63
    May 2015
    427
    What about WOT shift tuning are you having issues with? I dialed in mine about 90% to where I want it last night.
  4. #64
    Jun 2015
    20
    My shift are pretty much dead on to 50 rpm off every shift . Only had that 7000 rpm wrench in 6th who happened like 4 time in Mexico the rest is pretty much all dial in. Car run like a freak even with piston slap and weird tic sometime lol.
    Only other problem I have is my my 94 octane pump gas. It's very close to e85 in 70's and bellow but in hi temp and humidity it's not even close to e85. Access to good e85 is nearly non-existent over here!!!
    I know that limiter could have been a issue later in fall because with my 3.15 and 25.7 tires I am not too far already than that 7000 rpm in 6th in positive DA!!
  5. #65
    Jun 2015
    20
    Happy to confirm it also solved my problem. Ask for a 7400 rpm 6-7th shift it happen @ 7364 rpm. Very happy!!!!
    Will read correctly the description next time Lol
  6. #66
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by STEPH93LX View Post
    Are you guys multiplying the entire table by 105%? (I guess I'm not understanding how you fixed the issue)
  7. #67
    Jun 2015
    20
    Quote Originally Posted by LastPlace View Post
    For the 7000 rpm hard limiter because of the planetary. I Multiply all value by 1.15 so I should be good to 8000 rpm. If you need more adjust accordingly! Some just max it out. I personally don't, adjusting only to what I need as sometime just maxing things out can cause other issue on some functions.
  8. #68
    Jul 2016
    613
    Anyone know if Exceeding the torque value in the Transmission > Torque Management > Upshift > Torque Modulation > 1-2, or 2-3 ect will cause the transmision to up shift early or before the set OSS that is scheduled?
  9. #69
    Oct 2016
    Poland
    1,771
    Maxing those will not cause any issues. RPM limiter is still there no matter what you do.
    I was wrong about this trans only having ISS and OSS for sensors. This trans has more than 2 sensors:
    Intermediate Speed Sensor A - ISSA
    Intermediate Speed Sensor B - ISSB
    Turbine Speed Sensor - TSS
    Output Speed Shaft Sensor - OSS
    Transmission Range Sensor - TR
    Transmission Fluid Temp Sensor - TFT
  10. #70
    Jul 2016
    613
    mine is shifting earlier then the upshift scheduled oss on 1-2 and 2-3, any thoughts on this?
  11. #71
    Oct 2016
    Poland
    1,771
    It's always like this with AT transmissions. 6R80 had this too in 1st. 1-2 shift had to be scheduled to 9100 rpm to actually shift at 8200 rpm.
    This is how the converter works in lower gears when it's fully open - RPM is way higher than ISS.
    You have to raise it up way above what you expecting for lower gears.
  12. #72
    Jul 2016
    613
    I will try raising the oss schedule for 1-2 and 2-3 and see what happens. I will report back either way.
    EDIT: looking at my strategy I'm missing RPM Antic Shifts and Max Accel. rate Min Accel. - I'm not sure if these will cause the trans to Shift before the scheduled OSS.
  13. #73
    Jul 2016
    613
    You 100% correct, I had to request 7200rpm shift to get 7000rpm on 1-2 and 7400rpm shift to get 7000rpm on 2-3.
  14. #74
    May 2015
    427
    The 10r80 seems to be way more responsive than the 6r80. 6r80 I had to command ahead of time, not the same on the 10r80.
    Kris
  15. #75
    Oct 2016
    Poland
    1,771
    10R80 woks on completely new Bosch ECU
