Results 1 to 8 of 8
Thread: Where is tq managent timing retard coming from
    Baltimore, Md
    1,213
    Can see in a couple spots even steady state it yanking bunch all the sudden and some heavy throttle transitions
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Sep 2016
    Phoenix, AZ
    109
    It wont let me view attachment
    Feb 2018
    Arizona
    19
    wont let me see it either
    2011 Camaro 2SS Ls3 6spd manual
    Night fury cam/stock heads
    E85 /ZL1 Pump, 80lb injectors
    3.45 gears
    Baltimore, Md
    1,213
    I click them and they all download fine? Try another browser Im on Chrome
    Sep 2016
    Phoenix, AZ
    109
    I think its just the computer at work not seeing it for some reason. I pulled it up on my laptop and I can see it now. I cant see anything in torque management that is causing the issue. I wouldn't think that the default trans limit would be accessed as it appears to only get accessed when the tcm has communication failure.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Do you have the A/C when the timing is dropping? If so, zero the A/C Torque Reduction table.
    Russ Kemp
    Sep 2016
    Phoenix, AZ
    109
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Seems legit with intake air temps around 110.
    Feb 2015
    Perth, Australia
    974
    try disabling fast torque exit and 0 our burst knock retard
    I suspect its burst knock
