Results 1 to 10 of 10
Thread: LT4 supercharger conversion IAT location
    Aug 2016
    12
    Just finishing up a LT4 supercharger install on a LT1 stingray. Id like to get the IAT sensor out of the MAF with a breakout harness. My though is to remove the front OEM MAP from the supercharger and use this port to install the IAT sensor. Is there a better location or way to install an IAT sensor?
    Aug 2009
    Calibrating
    3,416
    That can work...
    I welded a spot on back of passenger runner and added my iat there when I did this..
    I was the first to do the lt4 swap on an lt1 if you need help with tune
    Aug 2016
    12
    Any additional help would be great. I’ll plan on the IAT sensor in the front MAP location, as I’m using the rear MAP location for a 3 bar sensor. I need a bit more time as I’ve decided to install the LT4 pump and injectors. Should make some decent power.
    Advanced Tuner veee8's Avatar
    Apr 2006
    449
    I make a conversion harness that takes the iat from the maf, and also converts from the stock 3 wire map and uses the factory LT4 4 wire map sensor in the back of the blower with built in iat.
    Feb 2016
    486
    Dsxtuning break out harness u will need other stuff too
    May 2020
    arlington tx
    28
    Quote Originally Posted by veee8 View Post
    is there some where i could get a tutorial on what sensors are needed on a lt1 with lt4 sc
    Aug 2009
    Calibrating
    3,416
    Quote Originally Posted by davispaintandbody View Post
    Can use the LT4 TMAP sensor, probably beta to do that with breakout harness from maf
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen5 Viper
    Ultima RS with C8 drivetrain
    May 2020
    arlington tx
    28
    is your breakout thge same as dsx ?
    May 2020
    arlington tx
    28
    dsxtuning vs www.crawford-racing.com breakout ?
    Dec 2023
    St. Joseph MO
    That can work...
    This looks like a pretty old thread but I would definitely take you up on that if the offer stands? Mine is running pretty good other than the most annoying tq man advance issue ever LOL. It will bog when you first start giving it throttle if you're slowly pushing down on the pedal and then almost like a switch being shut off or snapping your finger the bog goes away and it sounds like a normal LT4 again and takes off HARD (if you press the pedal fast you don't notice it usually but it's there). I cant just stomp on it in park or neutral like everyone else can cause it just bogs and sounds embarrassing but if i slowly rev it to like 1500 plus and then stomp into it, it sounds awesome! Other tuners have looked it over and helped me reduce the tq man spark in other areas but just cant seem to figure this part out. Doesnt help this build was done by a shop for the previous owner so I don't have any first hand knowledge of what they did other than what I can see physically and in the tune.
    Attachment 161367
    Attachment 161368
    Attachment 161369
    Attachment 161370
