Missing something but it never seems to want to lock up, I can command it to manually no problem
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
cammed? need to modify misfire tables or else lockup wont engage
Also check the brake switch input. Sometimes they are backwards, if you lightly touch the brake pedal while in cruise range, and it locks up, then the brake switch is working backwards the what the ECM is looking for, Common on older conversions.
www.crawford-racing.com
Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
