Page 20 of 20 FirstFirst ... 101617181920
Results 381 to 399 of 399
Thread: Incorrect / Missing Parameters? Let us know
  1. #381
    Dec 2015
    The Exhaust Temp Inverse Table under Engine-Fuel-COT, Lean Cruise is missing for the 2011-2014 Ecoboost F150.
  2. #382
    Oct 2007
    Crawfordville, FL
    2,456
    Quote Originally Posted by HC Engineering View Post
    Flange Temp Inverse is there on all those.
    Eric Brooks
    HP Tuners, LLC
  3. #383
    Jul 2010
    35
    Is it possible to add the trans shift schedules for 2010 Raptor 6.2L
    2010 Raptor Auto Shift Speed Tab
    2011 F150 Auto Shift Speed Tab
  4. #384
    Oct 2007
    Crawfordville, FL
    2,456
    Quote Originally Posted by TurboCamaro View Post
    It is being worked on.
    Eric Brooks
    HP Tuners, LLC
  5. #385
    Jul 2010
    35
    HI Eric
    Thank you very much
    I really appreciate it.
    Eldon
  6. #386
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Is it possible we could get the Sport Shift pressure and shift schedule tables for the 13-14 Mustangs?
  7. #387
    Jul 2015
    927
    2011 Mustang 3.7, MAF period parameter in the scanner.
  8. #388
    Jul 2016
    Richmond, TX.
    83
    2016 Mustang GT
    Scanner PID:
    Is it possible to read IMRC values Open/Closed?
    Transmission boost pressure per element?
    TCC speed ratio?
    Is the a gear shift change "actual" vs commanded PID available?
    Editor:
    Can traction control be disabled?
    Can car be put into OP spark mode?
  9. #389
    Mar 2017
    Hi,
    I see the last responce was in 2017...
    I have a issue with a 2016 Mustang that had some Whipple software on which we have to retune for additional mods. I have done this before so no issues there. Problem is some of the parameters is missing, namely Mass Airflow period. I running VCM Scammer V4.0.12 which is the latest. VCM Scanner missing Parameters.png
  10. #390
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by BBMS View Post
    Hi,
    Have you tried the 4.1.x beta?
  11. #391
    Mar 2017
    Hi,
    Yes downloaded beta (4.1.485beta) last night but still the same.
  12. #392
    Jul 2016
    613
    Submit a support ticket
  13. #393
    May 2018
    Germany
    590
    Hi,
    5R55S tuned with sct Shows the Option Shift Pressure in Trans.
    I miss this item in hpt files, that are not tuned with sct before.
    Best regards
  14. #394
    Aug 2016
    945
    Maybe this has already been addressed in a thread somewhere. I searched high and low but maybe I just did not search in the middle.
    Individual cylinder misfire pids for Fords would be great. I know the PCM is offering them as my Ford IDS/VCM2 has it, just have HPTuners up and running a LOT more often than IDS.
  15. #395
    Hi,
    a lot of parameters that are to see on the 05-11 civilian Crown Victoria and 08-11 Crown Victoria Police are not the see on the 2006 and 2007 Crown victoria Police interceptors.
    They do exist (because of the behavior of the ECU on the bench) but are not in the VCM editor.
    Thank you for asking us
  16. #396
    Jan 2018
    31
    I am not sure if anybody is monitoring this but I have a couple on EECV - 2002 Mustang GT
    EECV - FUEL - GENERAL - OFFSET MULTI vs PRESSURE
    The software seems to apply an additional decimal place and create a problem in the EECV when cells are entered manually or generally corrupt this table. The only way I could get the injector data entered in this table without the car going pig rich was to adjust the existing cells via the multiply box. A tip from another user in the forum. This is with being aware of the starting and ending values needing to be identical on the ford PCM as well. Somethings really off on this table.
    EECV - MISSING STARTUP FUEL ENRICHMENT TABLE (fuel_table_startup_OL )
    I cant find this for the life of me. It does not appear to be in the software. Can you please add it ?
  17. #397
    Oct 2007
    Crawfordville, FL
    2,456
    Create support tickets for missing parameters. Thanks
    Eric Brooks
    HP Tuners, LLC
  18. #398
    I have an open ticket that i never received a response to. It is on a 2010 Taurus Sho, so I realize it isnt I large priority on the list. My ticket number is 161248, I submitted it back in January.
  19. #399
    May 2018
    Germany
    590
    e38 6R80 - need VSS parameter to use 6th gear in higher range.
    Shift tables were ignored / restricted at WOT . It doesnt shift into 6th.
