Originally Posted by
RobZL1
I feel like we are talking about different things. If your g/cylinder hits 2.4 in the channels area in the scanner, but only 1.2 in the histogram in the scanner, then you simply change the axis in the histogram in the scanner. Just right click in the graphs area, and edit the axis for that histogram.
If the editor only goes up to 1.20, then change the axis in the editor. As noted, you can't add cells in the editor, only change the values. You don't have to make the gap between the cells the same either. You could go 0.80 0.90 1.00 1.20 1.40 1.60 1.75 1.90 2.05 if you wanted to, for example. If it were me, I'd keep some low end resolution out of boost, and resale just the last 10 or 12 rows of the table, since those are likely to only be hit under WOT where you wont need a ton of resolution. (In your current case, it would be using the 1.20 row for everything above 1.20 anyway.)
