Results 1 to 7 of 7
Thread: Reset Vector and program start location
    May 2003
    Santa Clarita, Ca
    962
    I was PM'ed with a question about this, so I thought it might make a good post.
    The intital reset vector for the 68332 is at 0x004
    From there you will find the processor setup routine and other various checks. After that, there will be and indexed JSR to the main program.
    All of this information is in the support PDF's from Motorola. You can find all of the CPU's setup registers.
    But if you are like me, who want's to read all of that boring stuff ;D
    Here is a sample from the 0937557 Bin.
    Reset Vector
    Code:
    ROM:00000000         dc.l $FFB000      ; Intitial Stack Pointer
    ROM:00000004 dword_4:    dc.l $500        ; DATA XREF: ROM:0004CE60o
    ROM:00000004                     ; ROM:0004CECCo ...
    ROM:00000004                     ; Reset Vector
    Code:
    ROM:00000500 ResetStart_500:             ; CODE XREF: Stop_6EC+6j
    ROM:00000500         suba.l a6,a6
    ROM:00000502         move.l #-$6000,d0
    ROM:00000508         move.l d0,d1
    ROM:0000050A         move.l d0,(dword_FFFFFB84).w
    ROM:0000050E         move.l #$200,d0
    ROM:00000514         move.w d0,(word_FFFFFB80).w
    ROM:00000518         movea.l #0,a0
    ROM:0000051E         movec  a0,vbr
    ROM:00000522         move.b (byte_3C2F).w,(d1.l)
    ROM:00000528         move.b (byte_3C30).w,(d1.l)
    ROM:0000052E         jsr   (ProcessorSetup_1410).l
    ROM:00000534         jsr   (sub_F1A).l
    ROM:0000053A         jsr   sub_10854
    ROM:00000540         tst.w  (word_3240).l
    ROM:00000546         beq.s  loc_54E
    ROM:00000548         jsr   sub_678E4
    ROM:0000054E
    ROM:0000054E loc_54E:                ; CODE XREF: ResetStart_500+46j
    ROM:0000054E         movea.l (Start_Of_Routine_323C).l,a2
    ROM:00000554         jsr   (a2)
    ROM:00000556         stop  #$2700
    ROM:00000556 ; End of function ResetStart_500
    Line 0x54E tell the CPU to load the address from
    0x323C into Address register A2.
    0x323C Dc.l $120A2 (longword)
    From there it's just a jump subroutine away to the
    major loops at $120A2.
    The only glitch with IDA is it call addresses FFFFFB84 instead of FFFB84. I have no idea why. Ida thinks we are in extended ram, not the TPU Ram.
    So when it comes time to create the Regbase, or Ram, it's going to be a LOT further away than it should be.
    You can still determine the correct address. Just leave off a few FF's when you try to find something in BDM mode.
    I have tried every possible combination to get it to display the correct range without any luck.
    If you know, please tell me.
    Happy hunting!
    Re: Reset Vector and program start location
    okay so i've abandoned the idea of my own disassembler now (i think i've lost at least 6 months off my life expectancy >
    I have IDA now and started on a couple of bins.
    I too was confused about the extra $FF IDA seems to throw in on those addresses. Searching thru the indexed calls is very tedious work.
    I count sheep in hex...
    Dec 2002
    27
    what is IDA where can a i get a copy and how do i use it. also what sort of buffer and speed requirements does the odb2 flash interface need hardware wise ? i was thinking about using a 68332 MCU as a rs232 to vpw interface. i know it can handle the 4x communications.
    Sep 2002
    Chicago, IL
    6,397
    Wow, I don't even remember this post. I will have to look into this more later.
    IDA is Interactive Disassembler.
    http://www.datarescue.com/idabase/
    download the demo here:
    http://www.datarescue.com/idabase/ida4down.htm
    IDA standard costs $400.
    We got this guy Not Sure, ...
    Sep 2002
    Chicago, IL
    6,397
    So you find the loc at x004 and go to that loc and start to disassemble.
    Then you find the:
    location and go there do diassemble.
    Are there any more branches where you must go manually to disassemble?
    Quote Originally Posted by Magnus
    Then you find the:
    many, many many, many
    just do a search for jmp (a2) and you'll see what i mean. indexed jumps within subs and also to long code locs. at the end of the bin 7Cxxx'ish there are heaps of jump vector tables.
    May 2003
    Santa Clarita, Ca
    962
    Then you find the:
    Tons of them. IDA stops disassembling anything after an RTS (return from sub).
    A lot of the subroutines are indexed and called by the loop counter x the base address. Thats what a lot of the jump tables are.
    The rest of the index tables belong to things like "table Vs Mode, Gear, Event etc.
