Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: L83/6l80 help
    Feb 2020
    35
    That looks better. Did the MAF code come back after you installed the new MAF?
    Mass air code P0102-00 came on after mins of idle time
    Also have codes P0650-00 and P10E1-00.
    Thoughts?
    Aug 2016
    945
    P0102, MAF low output makes sense for the 4" tube. If you just follow the write-ups for MAF tuning you will probably resolve that and have a much better running engine.
    P0650 just means that you don't have a check engine light wired up. You can turn that off in the tune under diagnostics (set to no error reported).
    P10E1 I can check tomorrow
    Feb 2020
    35
    Quote Originally Posted by IARLLC View Post
    Thanks. I was looking around at my tune trying to learn more about how HPtuners work and noticed that the vvt is set to none. Would that mean that the vvt isn’t active?
    Mar 2011
    Ripley, MS
    1,865
    You're correct. If the VVT is set to none, that means it has been deactivated.
    Feb 2020
    35
    ok here are some logs with the VVT on and a new maf curve suggested by a co-worker it starts cold or warm excellent now, looks like fuel trims are off tho thoughts? thanks again for the helpnormalallgears215.hplcruise75.hplwarmstartup.hpllukec10feb14tune.hpt
  6. #26
    Aug 2016
    945
    The logs show that this advice...is still needed
  7. #27
    Aug 2009
    Calibrating
    3,378
    Replied to your PM!! Larger houseing for the MAF lowers the Hz range so rescaling the MAF sensor is necessary!
    Zero out VVT entirely on a stock cam cost you power
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
