Results 1 to 6 of 6
Thread: Calibrations???
    Apr 2019
    14
    Calibrations???
    Can anyone tell me if the l99 and the ls3 share the same ecm calibrations?? If not, can someone chime in and tell me what?s different other than the transmission?
    405
    2,365
    L99 has AFM/DOD and Variable Cam, LS3 has neither.
    Apr 2019
    14
    Thanks but I know that, and I already deleted the the afm/dod and vvt, disabled them in my tune, and installed the actual ls3 cam 12623063.
    I?m asking about the ecm calibrations and operating systems. I was hoping someone could tell me if both operating systems were almost identical or way different??
    Oct 2013
    550
    The L99 and LS3 use very different camshaft profiles - which translates into very different calibrations.
    Use the compare feature in the software - you will see that the differences in the calibrations are extensive and significant.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    there are many many differences, timing is different because the engine sees load differently with an auto vs a manual, torque management is different. there are differences in fueling, and behavior due to clutch use.
    me personally i would leave the stock auto file, and just tune it to the new cam, its not going to be that far off, a couple of percent at best in the ve table
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Apr 2019
    14
    Quote Originally Posted by mbray01 View Post
    Thanks for the input, Much appreciated!!!
