Results 1 to 10 of 10
Thread: TMA kicking in at hi-rpm?
    Aug 2005
    335
    I?m having this weird issue where torque management advance is kicking in around 6100 rpm and pulling 9 degrees of timing. You can clearly see this blip on the dyno graph. This is the 2nd time I?ve encountered this on a 500 + rwhp N/A car. Not sure what?s causing it.
    GO RAIDERS!!!!!!!!!!
    02 C5 Z06
    8.8@160
    13,599
    We can't really tell either without the logs of it happening and the tune file along with it.
    Aug 2005
    335
    Here is log file
    02 C5 Z06
    8.8@160
    Dec 2019
    DFW, TX
    124
    Turn the A/C off
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by ShaneB View Post
    Turn the A/C off
    Yup
    2,922
    thinking the same thing.. Saw ac/defrost do this.
    Tuner at PCMofnc.com
    May 2003
    South FL
    1,395
    The A/C shouldn't do this. If it is, you can tune it out. I have never seen having the A/C on cause TMA on the street or dyno. But I suppose that doesn't mean it isn't possible. I'm assuming you guys have seen this or you wouldn't have commented? Only asking, not claiming you're wrong.
    [email protected]
    Owner/GM Calibrator
    Aug 2014
    Central, LA
    737
    Have absolutely seen it many times. Always at 6081 rpm. Mostly in camaros.
    Dec 2019
    DFW, TX
    124
    I've only ever tuned MY car, 2018 2SS 1LE Camaro, but every time I forgot to turn the A/C off, it would drop about 10-15* depending on if it was 93 or E85, and you could really feel that dip on E. It would only do it the 1st gear of a wide open pull though, so say I did a 2-4 gear pull, 3 and 4 would have full timing all the way, but 2nd would drop off from 6100-6300 and come back. Then you cruise for a bit then punch it again, same thing. And that was even with the A/C tables set to NOT do this, like disable compressor at 90% TPS and 4000rpm or whatever, didn't make a difference.
    Tuner lynmup's Avatar
    Dec 2020
    Omaha, NE
    111
    Turn the A/C off
    Happening to me and A/C on/off does not have any difference in the outcome. Only seeing it in 1st gear. Only able to do 1st and 2ng gear WOT pulls so not sure if it is occurring in 3rd or not. Researched and not seeing any definitive resolve for this issue. I did mess with my torque management/fast torque exit to no avail.
