Results 1 to 3 of 3
Thread: Intake CAM Angle Question
    Aug 2020
    20
    I am curious about the Intake CAM Angle PID. You can see from the screen shots I have the desired angle to start phasing 1* around 5200RPM and step up from there to 4* per the cam vendors recommendation. This looks accurate when I go to log. However I am seeing data in the 400, 800, 4400 & 4800 RPM where it should be 0. Do I have my table setup wrong in vcm Scanner? maybe bump the hit factor up to 5? or is this normal?
    405
    3,226
    There are 3 tables. Are they all set the same?
    Aug 2020
    20
    Yes all three tables are the same.
