Results 1 to 9 of 9
Thread: Commanded AFR vs actual - VE table?
    Dec 2021
    18
    Wideband is showing 10.4 - 10.8ish when the commanded afr is 12.75. Is this a VE table adjustment?
    Commanded AFR WOT 12.7 (per log)
    Desired FA Ratio WOT is 0.0809 (12.3)
    Actual AFR in WB WOT is 10.4 - 10.8ish
    FA+PE Ratio is in the low 12.*s afr
    This seems not right and a VE table thing. I've since pulled more PE out to see how that responds but haven't ran it yet.
    Wideband is in rear stock o2 location; truck is catless.
    07 Dodge Ram
    Inertia Spartan Plus cam: 214/222 Duration 0.566/0.556 lift 112 LSA
    Inertia heads
    5.38 gears
    40" tires
    8500 lbs +/- gross weight
    Attachment 117761
    Attachment 117762
    AFR vid from the log.
    https://youtu.be/8X6ZDM9S4wg
    (some easy wot with part throttle cruise towards the end)
    Jul 2015
    925
    Are you changing your PE value to get the actual AFR you want? If so, that's the absolute wrong way to do it.
    Adjust your VE so your actual meets your commanded.
    I actually have my VE zero'd out and adjusting AF's using the PE value. I'm doing this based on a tune recommended for my car....this is the wrong way to do it? I'm still learning myself and that's what I was recommended to do. Doing it this way I've been able to command my WOT AF's and normal cruising AF's with no problem.....Granted IDK, this could be the wrong way to do it.....
    Tuner in Training GaS Engines's Avatar
    Jan 2021
    48
    Quote Originally Posted by brr View Post
    if you still have NN on it uses PE tables, if you switch NN off you use VE tables...I suggest at least putting the VE tables back to stock settings and not listening to whoever told you to zero the VE tables. So yes that IS NOT the correct way to tune.
    2013 Charger R/T - 1-3/4'' Longtubes, Catless Mids, 180 T-Stat, CAI, 6.4 Manifold Swap, 370whp@5600/411wtq@3950
    Contact [email protected] for Engine Building or Tuning needs!
    ok, thanks for the info.....
    Yes my NN is still on.....
    I tried the NN training here with the recommended VE tables zeroed and my PE where I want and the car performed so much crappier than my butt dyno....
    I thought I was doing good as the HPT TQ readings were my highest at 293ft/lb with the zero'd VE tables and the NN on and just adjusted the PE tables.
    So, with NN on.....DONT 0 out the VE tables, and just adjust the PE tables to keep the A/F's where you want them?
    May 2018
    Germany
    590
    Did you first adjust the injectors ?
    Oct 2005
    baton rouge la
    411
    We have a cam we sell thats 214/228 so not too far off from yours. I've found best results disabling NN and tuning VE
    I only posted my findings to see if it may help "sredish" with his tuning Hopefully "sredish" red the responses as it should help him and it could help me
    Oct 2021
    Allentown PA
    363
    this is an 07 Ram...... No NN
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
