Results 1 to 17 of 17
Thread: supercharged GPEC2 SRT8 hidden fuel cut/torque limiter table?
    Tuner in Training Hydra Performance's Avatar
    Jul 2020
    +961
    19
    Unhappy supercharged GPEC2 SRT8 hidden fuel cut/torque limiter table?
    Howdy all,
    I hope you don't mind me reaching out for a helping hand, as I'm at my wit's end here. I'm in the process of tuning a cammed Procharged 6.4L SRT8 Challenger with with built motor, 3-bar MAP sensor and I like to think that the tune is close to completion with no issues except the following. At 3000ft elevation, it hits ~195-200kpa @ redline without issue, however down at sea level, where I see the same boost @ approximately 5800rpm it hits some sort of limiter and refuses to rev any higher. Now I have all the torque limiters and torque management nannies maxed out and have absolutely no idea what could be causing this. NN and VVT are disabled/locked-out and I'm using the VE tables to tune. Any ideas what's going on here?
    I have attached the tune in question, along with logs @ elevation without issue and on the dyno (where the problem manifests itself)
    Please advise, thank you!
    Mar 2021
    Pompano Beach FL
    278
    I will take a look. Do you have the stock read as well?
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Jul 2020
    +961
    19
    Quote Originally Posted by N2speed View Post
    Thanks a million! Yes, I do
    elie abdayem 392 hemi challenger base.hpt
    Nov 2009
    All Around
    3,149
    elie abdayem 392 hemi challenger hydra 3BAR 80lb v7_test.hpt
    you need to log better channels
    fuel source spark source
    all limits
    also spark control under fuel cutt seems disabled
    Jul 2020
    +961
    19
    Quote Originally Posted by SultanHassanMasTuning View Post
    all limits
    Yeah FWIW I logged throttle torque source in a later datalog (which unfortunately I did not save) and it remained @ "Pedal" throughout, despite the early cutoff (where you can obviously see the throttle closing)
    I will try again and get back to you ASAP, thank you very much for your assistance
    Oct 2005
    baton rouge la
    411
    Quote Originally Posted by Hydra Performance View Post
    Howdy all,
    Attachment 119221
    Attachment 119222
    Attachment 119223
    One thing that jumped out at me in the "arabi7" log is the ECT. Looks like the sensor failed and is reading -78*F I had a GC give me some fits a week ago, and it seemed the culprit was the ECT sensor. The jeep ran great until it got to operating temp. When it did, the sensor failed, and the gauge on the dash went to the bottom. The log would start reading correct again but the display on the dash would not. Once I swapped that sensor everything cleared up
    Jul 2020
    +961
    19
    Quote Originally Posted by white1 View Post
    What I found very unusual was that the indicated (graphical) ECT and IAT readings on the dash you see are not the same as the textual ECT & IAT values you see on the left half of the VCM Scanner. Didn't really bother figuring out the reason for the discrepancy as the text values appear normal.
    Jul 2020
    +961
    19
    Quick update for you guys. I performed all the suggested modifications to the tune and tried again. Still the same no change... It would appear as though its cuts out @ exactly 200kPA which leads me to believe that this may be something hardcoded in the OS? I have attached a copy of the latest tune & a few sea-level logs, both with and without the air filter attached. When the air filter is removed it cuts out approx 250rpm sooner but also very close to the 200kPa boost ceiling. Please advise :/
    elie abdayem 392 hemi challenger hydra 3BAR 80lb v9.hpt
    dodge dyno3 no filter.hpl
    dodge coastal hwy1.hpl
    dodge coastal hwy2.hpl
    So I'm not 100% on this, but I've been told and have heard that for the 09-14 gpec2a ecu's they do not handle boost levels above 200 kpa ~ 15 psi of boost. If this is the case the hack for this is to any tuning above 200 kpa as if it were 200 kpa. I have a 13 Challenger R/t with GPEC2a ecu, and I'm getting tuned tomorrow. I'll report back if I run into this issue on the dyno as well. I also have a 3 bar map, so many of the mods are the similar.
    Jul 2020
    +961
    19
    Quote Originally Posted by DakBuilder View Post
    What's happening here is that its simply cutting out/hitting an early rev-limit, making further tuning impossibru. What I might do, if there is no other choice, is to rescale the MAP sensor and all the affected load tables so that it reads 200kPa say @ an actual 250kPa instead...
    bored on my lunch break , did not review file but i would say put max map for 195 kpa
    have a good day
    Just wanted to report back, my tune was cleaned up by a tuner. I had some bad data put into the injector scaling. That cleaned up a lot of my issues. I'll get into the boost limit issues here soon
    Jul 2020
    +961
    19
    Just wanted to report back myself, putting max map @ 197kPa solved the issue and all is good now!
    May 2018
    Germany
    590
    did you measure the real kpa externally? Would be interesting.
    Jul 2020
    +961
    19
    Quote Originally Posted by f.creek-ranch View Post
    Not yet, delivered the car to the customer. Will definitely be doing this next time around @ the next round of mods
    Quote Originally Posted by Team_hellcat View Post
    have a good day
    Why is setting the max KPA to 195 the solution? I'm good with inputting those values, but I like to understand what is actually happening.
    Mar 2009
    S. Florida
    583
    Did you ever figure this out? Going thru the same thing with my Whipple build.
