Can a 2008 G8 be re-programmed to a 2014 truck trans?
2009 Maverick Silver G8 GXP M6 - 586hp
Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
Drivetrain Mods: Ram Dual Disc Clutch
Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
If the Service Numbers interchange, go for it. But you can't just go doing stuff like that without verifying interchange first.
The Service Number is like a part number, but is for the hardware only, it does not describe anything about what software/calibration is in it. A Part Number on the other hand is a specific Service Number with a specific calibration in it, that would be a direct install-and-go deal for a specific vehicle. Once the cars/trucks are more than a few years old you can't buy a bolt-in preprogrammed Part Number replacement anymore, you just get the basic compatible hardware and program it to the application. That way they can have one part on the shelf that 'fits' many many different apps.
2008 Yukon 6.2 TCM: 24275872 https://www.rockauto.com/en/catalog/...nit+(tcu),8480
2013 Yukon 6.2 TCM: 24275873 https://www.rockauto.com/en/catalog/...nit+(tcu),8480
Would appear there is an incompatibility between them, else they would have obsoleted one and replaced it with the other. Both are current numbers.
To be clear, if I scan my current 6L80 with my HPT, then I should be able to program the new rebuilt 6L80 from GM?
IT DEPENDS! There is no way for you or me or anybody anywhere to say whether it'll be a new-new totally blank TEHCM that HP Tuners can't detect, or if it'll be a reman TEHCM that's already had a cal put in it at some point and is detectable by HPT. Maybe the totally-blank thing was something they only sent out like that for a while but now they all have some generic placeholder cal in place, or maybe the new-new TEHCMs are still like that. If HPT won't detect it then it will have to be flashed the first time with SPS and you won't know until you plug into it and see what happens.
