Results 1 to 9 of 9
Thread: I need help explaining the mysterious misfire
    Sep 2021
    11
    I have RAM 2019 DT 5.7 with CAI, Lt headers catless, ATI dumber pulley, h pipe dual exhaust
    The truck was a true dual 2.5 inches runs great
    Recently I changed to a 3-inch H pipe
    Currently, I'm struggling with the misfire engine only at part throttle the check engine light blinking four times. When I scan the PCM, no codes show up! Afr 15.5 to 16.7 ��It happens at part throttle
    I checked the vacuum and exhaust leak?all good.
    However, I disconnect the negative battery; the AFR goes normal without a misfire. Finally, the truck runs normal I think the fuel trim has been reseted
    Four days later, the problem comes again where the AFR goes lean and misfires.
    Where should i start looking o2 sensors?
    Below video run at part throttle where the problem happen AFR goes lean and misfires
    https://youtube.com/shorts/5gnh1APClfc?feature=share
    At wot no misfire runs perfect !!
    https://youtube.com/shorts/nOZYJrvyoDs?feature=share
    May 2018
    Germany
    625
    you should check the fuel delivery.
    Oct 2021
    Allentown PA
    363
    Are you running 3in true Duals Now ?
    Sep 2021
    11
    Quote Originally Posted by rays04gtx View Post
    The previous set up was 2.5 inch true dual no cross over
    now H pipe 3in
    Sep 2021
    11
    Also i updated the thread with afr reading
    Mar 2021
    Pompano Beach FL
    472
    you should post a data log with the tune file,
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Oct 2021
    Allentown PA
    363
    Quote Originally Posted by Fawazalsabay View Post
    now H pipe 3in
    Might be my old age here, but if I understand you .
    it's 3in true duals with an H-pipe ,header to tail pipes , was 2.5 duals no cross headers to tail pipes?
    From my experience , your leaning it out and causing a Misfire....... How are the Knock sensors reacting when it flashes CEL light flashes 4 times ? My kids 02ram(with wiring PCM,and dash from a 2014)ran great with headers LT headers to 2.25in(w/Stock cats) to X pipe, 2.5 out to tail pipes. swapped it over to Headers to 3 in, Hiflow cats x-pipe 3 inch out. truck ran lean AFR would climb to mid15 till the SRV valve kicked in around 3400rpm, we lowered the "Charge motion device" Medium RPM disable to 2200 and added 1.15 Fuel from 1920 -3744 RPM air Charge(MG) 675 to 900 block, truck would still hit 14.1-14.5 in the same rpm area, we dumped more fuel in the same spot, no change, pulled some PT timing, didn't help any. finally went back to a 2.5in system front to back.
    Engine was a 5.7 Eagle, SRT392manual cam, some port work 2.08 intake valve/1.625exh valve.5.7 truck intake.
    Nov 2009
    All Around
    3,149
    always log the car and post the tune
    running leak will cause misfiring, poor grounds could cause it as well
    a datalog will show
    Sounds to me like you need to delete your p0420/p0430 ... seems to me anyhow..
