Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: Last two latest Beta's - Virtual Torque broken?
    Aug 2005
    Texas
    116
    Can you still use 4.x on another pc if you update one of your pc and mpvi2 to 5.x?
    28,774
    My bad. I apologize. My specific question is If I am using a mid version 4.xx and wanted to know if any or all of the items that could be "adjusted" that were no longer available in version 4.9 or so are now grayed out are now available as long as you take and pass the CAA course and enter in the code. I will now patiently wait.
    We have not added any tables back into the software that were previously removed.
    May 2003
    South FL
    1,592
    I don't know if it is just me or not, but on 5.04 I've unlocked the parameters and used it successfully. Then the next time I load 5.04 I can't change the parameters again. I look and my parameter access code is applied and valid with an expiration date in 2023. Yet I still can't change parameters. Last night I did everything I could think of, resynced interface, logged into the site to make sure the codes matched. Yet all of the sudden, no matter what, I can't edit Virtual Torque again. This is highly annoying.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    28,774
    Virtual tq is bugged in 5.04, you need to update to the newest beta as outlined earlier in this thread.
    May 2003
    South FL
    1,592
    Found that out on my own as mentioned in the other thread. Definitely missed the update to Beta in this thread because it WAS working for me before it broke lol
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
  6. #26
    Mar 2018
    451
    In mine the tables or switches, went away then I downloaded the next beta, they were back but greyed out. I then took the test and could edit them again. Next beta they are gone again.
    Why even take the test?
    Can I get them back with user defined parameters?
  7. #27
    28,774
    Quote Originally Posted by K44 View Post
    help-parameter access-refresh device link
    That will fix most similar issues.
  8. #28
    Mar 2018
    451
    Re-synced several times, the parameters are gone.
  9. #29
    May 2003
    South FL
    1,592
    You have to go back to the tunertools site and add a new device to get a new parameter access code and re-enter that one into the new beta. Whatever they did broke the original code you were given so you have to make another one. You don't have to retest at least. Basically it is just like adding another laptop with HPTuners on it to your portal/parameter access. I had to add a third code since I use multiple computers.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
  10. #30
    Mar 2018
    451
    I have the parameters in 5.04 they are gone in everything newer including 5.1.157 which I just did a clean install along with generating a new code in tunertools.
    Not very happy at this point.
  11. #31
    Is this still a thing?
    Downloaded the latest stable version and now cant adjust the virtual torque.
    Do I need to download the beta version to get it working again? tried going back the version it was (4.4) and it wont open the files anymore.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
  12. #32
    Tuning Addict
    10,887
    Still a thing, because there hasn't been a stable version released that includes the fix. The next release will contain all the changes made over time to all the Beta versions.
    Attachment 140161
  13. #33
    Apr 2023
    Has there been a fix for this?
  14. #34
    28,774
    Yes, long since fixed in the newest beta
  15. #35
    Advanced Tuner Guy With A Chevy's Avatar
    Aug 2023
    Corpus Christi, TX
    252
    So just take the test, acquire new device parameter access code and resync in order to change the virtual torque models airmass?
    Only after installing the BETA as stated above was I able to make changes to the gen V virtual torque model, reading goes a long way only if applied!!!
  16. #36
    Nov 2024
    Indiana
    We are aware and are working on resolving the issue.
    So this still hasn't been fixed? I'm on 5.04, added the device code, says I have access and cant change anything in VT table.
  17. #37
    Tuning Addict
    10,887
    Right click on the 5.0.4 installer and look at Properties. They haven't released a non-beta version since 9/2022.
  18. #38
    28,774
    Quote Originally Posted by mjayjr View Post
    Been fixed in the 5.1 beta.
