hello all. new tuner here. i have a 2011 Durango that i have done the mds delete and a non vvt TSP cam In: 214 Ext:222 LS: 112. Install seemed pretty straight forward with cam phaser mechanical limiter block installed, mds turned off, and cam phasers disabled. The issue i am running into is it will not stay running past fast idle.once i hit warm idle it will die unless i hold it at 2k rpm. i have checked the repository and read what seems like 1000 posts on here .
i attempted to add exhaust camshaft channels into my log as another post suggested, and while it seemed to have add the channels, i dont seem to be getting any data? (trying to verify my timing isnt off)
i also read that push rod length might be an issue. when i bought my kit from TSP i was told most guys run stock length pushrods with this cam? is there a way to verify this is/isnt the issue in the logs?
camshaft part number : 25-TSPHEMISTG1
Thank you in advance, im new to all of this and definitely feel like i am in over my head. But i am doing my best to learn.
