Results 1 to 5 of 5
Thread: Mass to be delivered / RPM multiplier cylinder 1-8 ??? ECM34177 -
    May 2018
    Germany
    590
    I took a look at this on 2010-2014 RT and SRT and have a theory..
    RT have fuel enrichement on cyl 5 and 6, are they hotter on high RPM ?
    SRT have the complete Bank 1 richen, Inlet correction by slanted throttle ?
    So this have to be corrected by changing the throttle/intake system ?
    Baltimore, Md
    1,213
    anyone familiar with these tables?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    I've been trying to tune bank-to-bank fuel trims over the last week using the RPM multiplier tables. So far, it does not look like they're having any effect. I tried setting the Bank 1 cylinders at 1.07 above 5,000 RPM, but fuel trims have not responded...
    Baltimore, Md
    1,213
    Quote Originally Posted by rockystock View Post
    Its populated with data in some OE SRT applications, so Id think it functions on SOME??
    Quote Originally Posted by GrannySShifting View Post
    Yes, the stock 392 calibrations add some fuel to Bank 1 at higher RPM. The suspicion out there is that the angled intake causes a little bank-to-bank imbalance. Two of the cylinders are dialed up around 5%, and the other two are around 2.5%, if memory serves...
    I have probably the opposite problem, where my asymmetric exhaust is causing some imbalance. From ~3000 to ~5000 RPM, Bank 2 peaks at around 6-7% richer than Bank 1 (my Bank 2 has an overall longer exhaust path).
