Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 141 to 160 of 221
Thread: Toyota Repository
  1. #141
    Jan 2023
    PNW
    9
    Stock BIN
    There is so much good info in this thread, I don't want to clutter it up, but since the real repository doesn't have a single Toyota File, here is a Fully Stock 2016 Toyota Sequoia 5.7L:
    2016Toyota Sequoia_5.7L_STOCK.hpt
  2. #142
    Jan 2023
    PNW
    9
    Quote Originally Posted by SlowNStock View Post
    Increasing the rev limit is straightforward, it's under "Engine -> Fuel -> Cutoff, DFCO", just increase to the value you'd like. Don't go crazy on the stock valvetrain...
    [/ATTACH]
    CUrious... if you raise the rev limiter, do we need to rescale every single map with RPM in it? I'm not seeing that being done after playing with that... Any idea how extra RPM would be dealt with if rev limiter exceeds what we see in maps?
  3. #143
    Quote Originally Posted by M_RED View Post
    If you exceed the upper bound of a table axis, it will continue to reference the highest value.
    So, if the highest Engine RPM cell is 6,000 RPM, it will continue to reference that any time Engine RPM is above 6,000 RPM; same is true for other parameters, like Absolute Load, for instance.
    As a result, you don't necessarily need to rescale, so long as the limiter is reasonably close to the max value or the table value is acceptable/conservative well beyond the max reference.
  4. #144
    Jan 2023
    PNW
    9
    Awesome,, good to know ! Thanks for sharing all your knowledge in here,,, Just started logging and playing with My sequoia, and I feel like I owe you a drink just for all your posts in here!
  5. #145
    Feb 2023
    Thank you, I am looking for Toyota .cuw calibration files. I downloaded your file and I'm looking at in binary. Are there really no Toyota files?
  6. #146
    Feb 2023
    SoCal
    20
    Hey SlowNStock thanks for all that you've put into this thread so far, I have a question about your files. What are you using to open .hpt and .xml files?
  7. #147
    Jan 2023
    PNW
    9
    In Airflow-ElectronticThrottle-DesiredAirLoad-Torque based...
    WHy is that table the inverse of Optimum Engine Torque Values? What is the relationship there??
  8. #148
    Feb 2023
    SoCal
    20
  9. #149
    Feb 2023
    SoCal
    20
    Did you have to Electronic Throttle added to your tuner? Because I don't have that tab..
  10. #150
    Mar 2019
    Ogden, UT
    102
    Quote Originally Posted by ryanallaire View Post
    Make sure you're in "Advanced" view.
  11. #151
    Feb 2023
    SoCal
    20
    Quote Originally Posted by JustDSM View Post
    Ah thank you. Can anyone tell me ALL the tables that need to be changed to affect shift timing? So far I've change torque reduction and shift scheduling tables and there's no change...
  12. #152
    Jan 2023
    PNW
    9
    Open it the scanner ( in the channels config box) and it will give you those channels to monitor..
  13. #153
    Feb 2023
    SoCal
    20
    Oh ok thanks again. Can someone look at my stock run? Are these normal readings for and NA 5.7 engine?
  14. #154
    Which tables, specifically, have you changed? If you post up a copy of your file, we can take a look.
  15. #155
    Feb 2023
    SoCal
    20
    So I've noticed some changes now after I've changed APP% ranges. I'm still trying to figure out how to use some of your tables though... I'm a stock NA 5.7 mainly wanting to have better shifitng and squeeze some more juice out of this motor, where should I start with the latter?
  16. #156
    Feb 2023
    SoCal
    20
    Here's a log with my modified shift scheduling, I couldn't get good WOT readings since it's raining here at the moment..
  17. #157
    May 2013
    8
    Anyone have this file 89663-ywn01?
  18. #158
    Feb 2023
    SoCal
    20
    I'll attach my file tomorrow
  19. #159
    hello .. how you you get this file sir ?
    how u read ECU Toyota with HPtuner sir ??
  20. #160
    Feb 2023
    SoCal
    20
    Quote Originally Posted by mr.joker View Post
    You download the file into your computer, open VCM editor and open the file..
