Results 1 to 8 of 8
Thread: 2022 Ram 3500 6.7 - Disabling speed limiter
    Dec 2022
    9
    Guys, I would like to ask a question. A customer asked me to remove the top speed limiter on the Ram 3500, which is set at 170km/h. Is it possible to perform with MPVI3 by OBD port?
    Dec 2022
    9
    Goodnight! Could someone help me if it is possible to change the maximum speed limiter?
    I would recommend AlfaOBD for this type of change. It is available on Android or Windows. You may need a bypass cable depending on the year.
    2019 CCSB Bighorn - Excited HP Tuners finally supported Cummins CM2350&2450 platforms
    Oct 2005
    baton rouge la
    411
    You will need the bypass cable
    I wasn't aware Alpha could change the speed limiter.
    If it cannot, you will also need the PCM unlocked in addition to the bypass cable in order to flash the change to the PCM
    Dec 2022
    9
    And what is the best interface to use AlfaOBD? Tks
    I have always just used Android but I know there are some features that only work with Windows (not sure which ones).
    This is the bypass cable I use:
    https://www.kaodtech.com/product-pag...-module-bypass
    Banned
    Jan 2022
    fountain valley
    2,379
    obdlink mx+
    Banned
    Jan 2022
    fountain valley
    2,379
    *I believe you would be able to connect a lap top running windows with any bluetooth interface (interface that uses elm 327 protocol) but that one ^^^ I know works
