Originally Posted by
TheMechanic
BlueCat is a GREAT tool, BUT you have to be careful and very thorough about entering every spot with data that is accurate to the VEHICLE. You need to first and foremost correct your data in the tune. ALL OF IT. Meaning tire size as measured with a tape measure not tire size on tire. Actual diff gear not what the OS says. Actual injector data, not what the OS says. etc. etc. That is an absolute must first step.
Then you can use BlueCat to mod the transmission. Of course as I said before don't remove TM when you are dealing with a 4L60e. You want good positive engagement, restrict TCC to 4th gear at less than 50% throttle. Good firm shifts are what you want. Reduced shift time is what you want. Timing reduction during shift is what you want. Start adding power and a good transmission guy is what you want.
