Where in the scan tool can I see my FTC's. Under which veiw ( dash, table, histogram, etc...) I see which cell I'm in with the table view, but I can't see them all at once. What do I need to do to get this view?
01"SS"
01"SS"
" '01 SS "
use VCM Scanner but run the logger (the record button) instead of just the scanner. At the end, save your data (in the scan menu item), and then export it to a .csv file. You can open the .csv in excel or use Tiggerfan's HPT calculator at http://www.tiggerfan.net/ltft.php
Not sure if you were asking if there is a way to view all the FTC's at once or not, if so, you are only in 1 FTC at a time depending on what the engine is doing. Each FTC represents a different engine state. There is another thread on here somewhere that lists all of the FTC's and what they are for.
Eric - 01 Silverado 5.3 ECSB
ET: [email protected] 1.77 60' 5200 lbs
Crappy website about my truck
My Myspace page
Usually contains explicit material (language, etc..)
It's Peanut Butter Jelly Time!
Thanks, I found it.
" '01 SS "
