Results 1 to 20 of 20
Thread: GPEC2A changing stoich value does what?
    Banned
    Jan 2022
    fountain valley
    2,379
    no one will ever find this in that srv thread
    Aug 2021
    36
    I agree, there is a ton useful information here also.
    I feel like no matter what stoich is set to, on narrow band vehicles, it's going to trim to 14.7 with gas. I can and have been wrong many times. As I understand narrow bands run 0-1v, so changing stoich (my thought) is that it would basically change the ve calculation and my trims would be off. Tune ve and it's back at 14.7 target. Or in pe it would run richer than target (I target about 12.2 afr). So tune pe and it's all back where we started.
    Maybe it's different with wideband cars.. I wonder if that's where the confusion comes from. Maybe I'm wrong. I am still learning.. But ultimately I'd like to know if changing stoich would actually change anything and benefit me any..
    Banned
    Jan 2022
    fountain valley
    2,379
    Regarding stoich settings - that is the initial target for the "math" in the PCM. It will still drive to the narrow-band voltage for stoich and just cause a wider variation in fuel trims to get there.
    For example, if you change the stoich setting for more fuel, you will just have larger negative fuel trims. You will not change what the narrow band sensors can read. The Hellcat uses wide band sensors, so it may be different.
    "It will still drive to the narrow-band voltage for stoich"???
    what is IT and what voltage is that?
    Banned
    Jan 2022
    fountain valley
    2,379
    thanks for the article
    i saw one explaining lambda and the pump wide bands use i will find and post
    still dont know what you mean by IT
    or why 4 wire sensor that has 0-5v output is being called narrow band
    Aug 2021
    36
    I'm fairly certain the narrow band o2 sensor uses a 0-1v signal. I don't know which cars use a wideband but fairly certain trucks use narrow band.
    Please correct me if I'm wrong but a narrow band will switch between above and below .5 volt to determine stoich.
    I will look at a log in a second and see what the voltage reading is on my o2s to be sure
    Banned
    Jan 2022
    fountain valley
    2,379
    lets not talk about how a narrow band sensor works
    that is in the article SB posted above
    lets talk about what all is actually effected by changing the value in the tune (stoich)
    Banned
    Jan 2022
    fountain valley
    2,379
    *the 4 wire sensors in my scat are not narrow band
    Banned
    Jan 2022
    fountain valley
    2,379
    that log ^^^ is from my scat, not a hellcat (3.3v)
    so... changing the value in the pcm... does it change the mixture at idle or not?
    you had said the trims will be further off but that doesnt make sense
    can you explain your theory?
    Banned
    Jan 2022
    fountain valley
    2,379
    you know i woulda already if my car were together right now
    if its not changing the mixture OR what the sensors call good, what does that value do?
    its a variable... what does it vary??
    Banned
    Mar 2022
    Indiana
    4,289
    Changing stoichiometric in the tune affects airflow calculations. No different than changing fuel injector flow rate. Because of the way a narrowband functions, they will always try to maintain a physical stoichiometric ratio in closed loop no matter what fuel is used.
    An example where changing stoichiometric is useful is going from regular gas to some blend of ethanol. E30 you'd set 12.96, and that way airflow wouldn't have to be re-tuned. All you have to do to understand this is look at a FlexFuel tune. There's a range of stoichiometric ratios on the fueling side but no range for airflow tables.
    Banned
    Jan 2022
    fountain valley
    2,379
    and the 392 uses 0-1v narrowband sensors?
    Banned
    Jan 2022
    fountain valley
    2,379
    same thing
    just calculations. none of it is real. i mean the engine is a pump, that is real. but think about ve
    changing ve calculations changes fueling
    cant change the actual airflow
    Nov 2019
    315
    Changing stoich will just skew the fuel trims during closed loop but the vehicle will always target lambda 1.0 using the narrowband O2 sensors.
    However, once it's in open loop, then the stoich change will affect the actual lambda/AFR because it does not rely on O2 feedback here.
    May 2018
    Germany
    625
    Im not sure what you mean,
    but changing the stoich in the pcm does nothing at closed loop, because ANN will do this, as long as it is activated.
    WB are only used by Hells.
    Apr 2023
    LEXINGTON N.C.
    7
    can you make a narrow band car run on wideband?
    Banned
    Jan 2022
    fountain valley
    2,379
    not without changing the os and who knows what in the controller
    maybe start a separate thread on the subject?
    Banned
    Mar 2022
    Indiana
    4,289
    Quote Originally Posted by CHARLZ1FORD View Post
    No. Why would you want to? The accuracy of a wideband decreases over time. Some Fords use widebands, but they are double checked for error with narrowbands through FAOSC.
    If you want goofy non-stoich fueling full time then you'll have to run open loop.
    Apr 2023
    LEXINGTON N.C.
    7
    if that is the case then why run it in the hellcat that has the same gpec2a
    im doing my best to post photos of the wiring but it insists on not uploading the photos but the only difference to the wiring is an extra 4 wires.
    main reason i would like to run it is to make the car actually run the afr i commanded.
    Banned
    Mar 2022
    Indiana
    4,289
    Right. Again, why would you want to run anything other than stoichiometric? Lean cruise maybe? Being able to tightly control fueling to maintain stoichiometric ratio is a big part of why modern engines have the efficiency and longevity they do. Might as well run a carburetor if that doesn't mean anything to you.
    Using a wideband full-time, like in the Hellcat, gives the advantage of precise fueling during power enrichment. As far as PE, there are things called rich-best-torque and rich-best-power. The wideband is able to compensate for environmental conditions and fuel mixtures to maintain FAR during PE. This maximizes engine power and engine safety. With narrowbands the tuner sets PE, but it's simply open loop.
    May 2018
    Germany
    625
    An old post I stumbled over.
    As long as ANN has the control over stoich, there is a way to control it over a wideband.
    I use this solution in older cars with Bosch injection.
    Zeitronix uses a wideband with a controller wich converts it into a narrowband signal.
    With a Software u can correct or fake the AFR as u want it to.
    Maybe some want to test it, in my older cars it runs perfect.
