Page 2 of 7 FirstFirst 123456 ... LastLast
Results 21 to 40 of 124
Thread: ZF8HP70 fails 1>2 shift under WOT
    ZF8HP70 fails 1>2 shift under WOT (slips to rev limit, limp mode)
    Quote Originally Posted by DodgeBoy_8HP View Post
    Hello!
    Could you share your tune and log?
    DodgeBoy.
    YouTube: https://www.youtube.com/@dodgeboy2785
    DodgeBoy, I responded to your email. Thanks.
    Banned
    Jan 2022
    fountain valley
    2,379
    i fixed another hp70 tune at the track tonight
    scat w 3500 convertor that had lost 1-2 shift
    lemme know if you need help
    ZF8HP70 fails 1>2 shift under WOT (slips to rev limit, limp mode) - Dyno
    how did that dyno session go?
    Had delays due to fuel delivery issues. Dyno scheduled for next week. The compression is lower on this forced induction 6.4L (9.7:1) to run on 93 octane pump gas. Hoping for 550-650 (Dynojet dyno), or 450-550 (Mustang Dyno) as a baseline range with only 63lb injectors and 10psi boost.
    Adding another 300Hp with bigger injectors and a smaller supercharger pulley may not be a good idea for the stock ZF 8HP70
    OK. Thanks!
    My first pre-dyno test was a 5.0 Mustang yesterday, on a second gear rolling start. Smoked it. I got a lot of WTFs and laughs. Since the new "stock" Mustang comes with anything from 315 to 480 HP, it probably was not the top performance stock version at 3,752 lbs. The fat 6,600 lbs. of Durango with 3 passengers in it without SRT or Hellcat badging was not supposed to do that
    Apr 2020
    38
    How did you fix the 1>2 shift?!? It wont help me now, but I'm sure others would appreciate the info
  6. #26
    Banned
    Jan 2022
    fountain valley
    2,379
    it sounds crazy
    spoolboy knows, he did not call me nutz
    some of the switches got reversed somewhere during the latest revisions
    thx hpt
  7. #27
    ZF8HP70 1>2 WOT shift slips to rev limit, limp mode, Circle D2800, 562WHP
    DYNO RESULTS - 562WHP (SAME AS STOCK HELLCAT DURANGO):
    Example Stock Hellcat Durango Specs and Dyno Reference Comparison:
    Using an 8HP95 (900Nm) transmission, a "stock" 2021 SRT "Hellcat" 6.2L Durango produces 562WHP/531WT (according to Hennessey Performance) on 93 octane pump gas with stock tune, 9.5:1 compression ratio, 11.6 lbs. boost, and 57lb (600cc) injectors.
    https://www.youtube.com/watch?v=n4WenoBjHjo
    My Specs and Dyno Numbers:
    Using an 8HP70 (700Nm) transmission, My 2017 Durango with forged 6.4L (392) produces 562.87WHP/524WT (Dynojet, yesterday) on 93 octane pump gas with a conservative tune, 9.7:1 compression ratio, 9.8lbs. boost, and 63 lb. (661cc) injectors. My 6.4L engine has 2 lbs. less boost than the reference 6.2L Hellcat motor and seems to have the same power but only RWD with the 8HP70.
    Additional 6.4L Power Options:
    If I reduce the supercharger pulley size by 1/4" from 3.75" to 3.5" using the same 63lb injectors, this should increase the boost to the same as the Hellcat and exceed stock Hellcat power by 50WHP for a total 612WHP. The 63lb injectors may be close to their limit and may require 80lb injectors. Also, this may be too much for the 8HP70 transmission.
    A 1/2” pulley reduction to 3.25” would increase my boost to 13.8lbs. and increase the power to 662WHP or 100WHP over a stock hellcat Durango. [UPDATE 01-18-2024] Done. Boost is now over 13 PSI, estimated 680WHP
    0-60:
    The 6.4L Durango weighs at least 6,300 lbs. with larger engine, SRT aftermarket 9.5" wide rims, and 295/40ZR20 tires. Not sure what the 0-60 would be as I have to let off throttle before the 1>2 shift to avoid limp mode, then I can go WOT. The stock Hellcat Durango claims a 3.6 sec. 0-60 on a perfect run, if actually possible, without special tricks including no rear seats, cold day, special tune, launch mode etc. Regardless, off-the-line using the same tires with even HP, the AWD 8HP95 Hellcat will do better than the RWD 8HP70. I should be able to get under a 4.0 sec. 0-60 on the RWD Durango with the current configuration.
    However, with more HP (smaller supercharger pulley) past the 0-60, I should be able to reel-in the stock Hellcat even with groceries .
    Last edited by Enthusiastic; 01-18-2024 at 06:01 PM. Reason: added categories, clarification on 0-60
  8. #28
    Aug 2021
    Indianapolis Area
    468
    Quote Originally Posted by Enthusiastic View Post
    Perfect! I just replied to you.
    Thanks.
  9. #29
    ZF8HP70 fails 1>2 shift under WOT - Mechanical
    Thanks.
    I will be holding off on the tune. I found a deal with a great discount for a beefed up, tested, tuned, and installed 8HP70 good to 900WT (Ft Lbs. Wheel Torque). The highest I may ever get is 640WT. This should be plenty of room for longevity. Thanks!
  10. #30
    Banned
    Jan 2022
    fountain valley
    2,379
    900 ft lb that means it comes with sipples billet drums
    dont get burnt
    dont pay 5 grand for a stock trans
  11. #31
    900 ft lb that means it comes with sipples billet drums - this is good, right?
    dont get burnt - ? Generalized statement. knife is sharp. Assumption of no research. Parts, knowledge, and labor to install is not free
    dont pay 5 grand for a stock trans - ? Price assumption, incorrect, much less, price includes install. Your first statement contradicts your "stock" statement. Confusing statements.
    No mention of this in our private conversation
  12. #32
    Banned
    Jan 2022
    fountain valley
    2,379
    on the phone i tried to suggest you learn how to set up scanner a lil better and log and find out if what you have is really shot before you swap it out
  13. #33
    Jul 2021
    236
    Hiw did you fix it? Ive got the factory convertor in my 5.7 and it wont shift until i hit the rev limiter
    2019 challenger rt
    92mm hellcat throttlebody
    ported 5.7 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers
    Vs 78/75 turbo
    e-85 tuned
    3.70 lsd
  14. #34
    Banned
    Jan 2022
    fountain valley
    2,379
    which version were you using when you wrote the last calibration?
  15. #35
    Nov 2023
    I have a 2015 Ram cammed, procharged, and 3600 stall circle D. I am having this issue. How did you fix it?
  16. #36
    Aug 2021
    Indianapolis Area
    468
    Quote Originally Posted by miccrohurst View Post
    In the past couple of months I have worked with a lot of RAM swaps (to ZF 8 speeds). It is quite a common issue.
    The solution is a full transmission re-tune: Combination of torque converter, shift pressure, shift timing, shift RPM and line pressure.
    Each case is unique (under my eyes). There is no "one size fits all", once every single engine and transmission are unique.
    Thanks.
    DodgeBoy.
  17. #37
    Banned
    Jan 2022
    fountain valley
    2,379
    How did you fix it?
    not by rewriting the entire tune
    just by playing with a few switches
    i think they got switched in the software update
    which version are you using???
  18. #38
    Jul 2021
    236
    If i posted my trans tune, could you look to see if anything looks off? Ive tried to fix it and had multiple Professional tuners look and try to fix but nothing worked.
    2019 challenger rt
    ported eagle heads
    Vs 78/75 turbo
    e-85 tuned
    3.70 lsd
  19. #39
    Banned
    Jan 2022
    fountain valley
    2,379
    sure
    email me the current tune and a good log
  20. #40
    Jul 2021
    236
    sure
    I sent you an email with the most recent log and tune that was in it at the time
    2019 challenger rt
    ported eagle heads
    Vs 78/75 turbo
    e-85 tuned
    3.70 lsd
