I Recently did a dod delete On 09 Silverado. Including tower plugs, non dod lifters, gen 3 cam, 3hole 4x cam gear, disabled the dod in the ecm,and i replaced the oil pump. The pump I used a m295 I?m wondering if that?s why I?m not getting the oil pressure I?m only getting 10 cold then when it warms up it goes to just above 2. All of this is according to the vcm scanner. I will post the log
