Hello all!
I have a 2006 Dodge Charger Daytona R/T(Mod list below) with what I believe to be some tuning issues.
After getting the parts installed I had it remotely tuned via a DiabloSport T1000 with a reputable guy(Tuner A) and it fired up fine but had some drivability issues:
Car speeds up itself slowly(will even shift gears when the RPMs got high enough) and trying to stop would cause it to fight it with lurching until I overpower it with the brakes, cruise control wouldn't work properly and no decel ever. I'm assuming all these problems are in the same bucket.
After several revisions the issues never went away(honestly felt like nothing was changing besides idle RPMs... but can't confirm that and the tuner wouldn't tell me his changes) and he said it was mechanical and to fix it first.
After looking over everything on the car again(including VAC and compression tests) and finding no problems, I went with another tuner who was just as reputable(Tuner B). Now his tune didn't have the above issues at all, only it had a different problem:
The car would stall with the LIGHTEST throttle touch; RPMS drop like 200-300 and stall. I could push the pedal harder and get past the dead zone, but leaving stops or reversing, etc. was terrible. After his several revisions and introducing new issues(one of which were causing my LT's to glow ONLY in P/N...) he just "Ran out of ideas" and started ghosting me...
So I got an HPT to look into the files myself and try to start revising myself.
Can you veterans spot anything in either tune that would cause these?
Specifically I would like to get Tune B's light throttle stalling fixed at least, so I can comfortably drive the car and start logging and tuning.
Thanks for getting this far and ANY help would be so very gratefully appreciated!!
MOD LIST(anything not listed is stock with only 25k miles):
Inertia's Spartan Plus Cam
Inertia's BV Ported heads(with the good 6.1 exhaust springs) milled .030
Kooks 1 3/4" Long Tubes with their catted mids.
MagnaFlow "15628" 2.5" Cat-back.
6.1 Chain Tensioner
6.1 Crank Pulley and belt
non-MDS Lifters
AEM Wideband
AFE Stage II CAI
Billet Tech Catch Can
255/55/18 Nitto tires.
P.S. Uploaded Stock tune too, just in case.
Tune A.hpt
Tune B.hpt
Stock.hpt
