Page 7 of 19 FirstFirst ... 3456789101117 ... LastLast
Results 121 to 140 of 379
Thread: Tune & Log. Gen VI CBB 1999 Vortec 7400
  1. #121
    Jun 2023
    241
    Sweet. I think this will be the fix.
    If you think about it... it's amazing that these things run! We've sure come a long way from the old Otto engine!
  2. #122
    Jun 2023
    241
    I also decided to remove a variable by ordering a set of standard rockers. They should be here tomorrow and I will get the pattern from one cylinder and double check the pushrod length with the checker and see where I am then. This should allow me to get the length perfect and eliminate the rollers as a source of noise. I also have a pair of valve covers that I am cutting the top off of so I can pinpoint the noise if there is still any.
  3. #123
    Jun 2023
    241
    Ok, so here is another question while I am waiting for parts and sunshine... I replaced the stock valve rotators with CompCams CCA-4779-8 Valve spring locators. Does that seem correct?
    COMP Cams Valve Spring Locators 4779-8COMP Cams Valve Spring Locators 4779-8
  4. #124
    Banned
    Mar 2022
    Indiana
    4,289
    Yeah seems fine.
  5. #125
    Jun 2023
    241
    Ok, so here is what I did. I took an additional 0.025" off of the length of the OEM pushrods, then went to the nearest 'off the shelf' size. These came out to 7.600" and 8.550". I then used the pushrod checkers and set them to those lengths and got these patterns:
    I still hear 'click, click, click'. I also checked the pushrod openings in the heads and did not see anything getting close nor did I see anything hitting the guides (in and out, I do see where there could be contact side to side).
    I am on the fence about ordering a set of stamped steel, 7/16" stud, longer hole rockers simply to get this thing quiet so we can tune without the knock sensors throwing things off... I'm in it this deep, what's another $100 right ??? The noise I hear is most definitely at the rocker and I can make them make noise if I simply grab them while preloaded and turn side to side, I get a click, click.
    I also made this so once I get the pushrods in there I can make sure it all looks good running and pinpoint the noise if it is still there:
  6. #126
    Jun 2023
    241
    Quote Originally Posted by oldpartsnrust View Post
    So, are these the correct pushrods for the 1999 L29 BBC? The ones in there are 3/8" but seem to have a ball, rather than a formed tip. Is this the same?
  7. #127
    Banned
    Mar 2022
    Indiana
    4,289
    Man what the hell that sucks that the noise is still there. I'm sure you're getting fed up with it.
    Side to side noise huh? Have you tried to see what's going on by watching them while someone turns the motor over?
    Is there any chance the spring retainer is hitting the bottom of the rocker arm? I see a ring of brighter metal on one of them, but that may be the way they are made.
    Those are nice pushrods and they'll work. The formed tip will have the same profile as a ball end where contact happens.
    Here's a good article I came across about rocker geometry.
    https://www.w8ji.com/setting_shaft_rocker_geometry.html
  8. #128
    Jun 2023
    241
    There's a lot in that article!
    I did order the stamped steel long slot 7/16" stud Summit rockers. I also ordered those pushrods at 7.600" and 8.550" as per the stock minus the 0.025" which I checked with the checker rods that gave the third pattern above. SO they should be here on Thursday or Friday and I will put it all together QUIET like this week/weekend. Thanks again for all the help and patience! I am pretty sure the roller tips are making noise, but also pretty sure that a majority of the noise was/is from the too long pushrods. I will assemble with stamped for lower noise and then after it is tuned I may swap in the roller tips to see if that causes any knock reading. Of course that is assuming it isn't the actual lifters making the noise!!!!
  9. #129
    Jun 2023
    241
    Now, how do I get this all together without the wife knowing how much I ACTUALLY spent? Anyone have any experience in obfuscating funds?
  10. #130
    Jun 2023
    241
    OK, got the pushrods AND the stamped steel long slot non-roller tip rockers... going to put it together today/tomorrow so I hope to have a log shortly!
  11. #131
    Banned
    Mar 2022
    Indiana
    4,289
    Hoping for the best.
  12. #132
    Jun 2023
    241
    Always something. I think I am getting there with the noise. I preloaded 1-1/4 turns and they quieted down considerably. I was going to road test and get some more logs and see if it was quieted, but the trans cooler lines are leaking! UGH. I also tried something for the high IATs, but haven't been able to test that yet either....
  13. #133
    Banned
    Mar 2022
    Indiana
    4,289
    Haha creative.
  14. #134
    Jun 2023
    241
    Alright... Got the trans leak fixed. It was the fittings at the radiator. Had to replace the whole thing The lifters/rockers are much quieter with additional preload. Took them to 1-1/4. Spec is 1/2 - 1-1/2 turns past zero lash. Got the insulation on the airbox and intake tube. SO, I plan to finally get a new log tomorrow assuming no further catastrophes. Sheesh.... Thanks for the patience and help!
  15. #135
    Banned
    Mar 2022
    Indiana
    4,289
    Looking forward to it.
  16. #136
    Jun 2023
    241
    OK, so I think there is maybe a single or two 'bad' lifters in here.... You mentioned Morel lifters. Do they make lifters that I can drop in and not have to do the whole buy new pushrods deal over? When I start and warm up fully there seems to be one or two that start clacking intermittently. The oil pressure is solid 60PSI on cold start then gradually lowers to like 20 at idle, but will jump to 45-50 when the throttle is goosed. The engine guy had me get extra clearance bearings as he likes stuff loose. The click sound doesn't get worse, nor better when warmed up and it is somewhat sporadic. I can go another 1/4 turn on the preload to see if that may get rid of the last of the noise. I was going to contact CompCams to see if they would swap the pair out if that doesn't do it. I have also heard that these aren't the best lifters to begin with and I'd rather not go thru that whole exercise if there is a chance that it is just crappy lifters from the get go. I have the specs, how do I see if there are some Morels that may be plug and play??
    Comp Cams Roller lifter 900-16
    They are .842” diameter, weight 121g and the seat height is 2.66”
    It is definitely worlds better than with the wrong pushrods and I am maybe just being picky at this point... The thing that gets me now is that it seems to be one or two rather than the whole chorus of them clacking away.
  17. #137
    2,875
    Not really anything plug and play inside a motor unless you get lucky. The tolerances are just too tight.
  18. #138
    Banned
    Mar 2022
    Indiana
    4,289
    Those comps are stock replacement lifters as far as I can tell. Comp can be hit and miss on quality. I did their trunnion upgrade kit and it started to eat itself. Turns out there was a known issue with heat treatment.
    Morels are good, but really expensive and probably overkill. Hard to beat Melling for stock lifters. JB-7003.
    Try full preload like you were saying before you start changing stuff out.
  19. #139
    Jun 2023
    241
    Well, got it back together. Sounds ok'ish.... I imagine it is just gonna be a bit noisier than stock as it were. There doesn't seem to be a defined clack, but rather just a bit louder all around. It seems that the knock retard is still there even with the less noise and the cooler IATs. Maybe I wound up with more compression than I had expected? Here is the log.
    8-Lower-IATs-3-full-preload.hpl
  20. #140
    Jun 2023
    241
    I had run the numbers a few times, but I wasn't 100% sure on the volume of the heads. These are stock Vortec L29 heads (casting #10141279) that I thought had 100cc chambers.
    Head gasket is 4.370 in. Bore, 0.030 in. Compressed Thickness (GM part #12554769)
    FORGED 4032 MAHLE -3CC FLAT TOP 4.310" Pistons (engine guy had them bore to 4.315")
    6.385" I-Beam rods
    4.25" stroke crank
    CompCams Xtreme Energy Computer Controlled 212/218 Hydraulic Roller K-Kit Chevrolet Big Block GEN VI (K01-412-8) at 0 degrees
    Stock deck is between 0.020" and 0.025" which I had decked by 0.010" to 9.790"
