Results 1 to 20 of 30
Thread: Import Injector Data
    Oct 2022
    NEW CASTLE DE
    30
    Hello all. I just ordered new injectors for my 89 S10 that has a 2006 6.0. The engine is stock other than a stage 2 cam and springs. According to data logs it seems I'm running out of injector flow. Truck idles, cruises great, but when I stomp the pedal it acts like it's starving for fuel. Factory injectors are 25 lb. I ordered 50lb injectors from Glenns Auto Performance that were highly recommended. How do I go about importing the data from the new injectors to my current tune? Forgive me, I'm very new to tuning. Thanks
    Tuning Addict
    10,887
    Do you know the part number on the injectors? (the vendor, who did nothing but mark them up by 200% (edit: sorry, more like 300%) and then resell them, isn't all that relevant for finding which data they use)
    Oct 2022
    NEW CASTLE DE
    30
    12613412 is the part#
    Tuning Addict
    10,887
    Attachment 136580
    Pick the tab at the bottom for your injectors. The tables have the same titles as the tables in your file at Engine > Fuel > General > Injector Control. There are two versions of the two tables that differ between regulator types, make sure you know what yours is and then use the version that matches.
    Tuning Addict
    10,887
    (same data, but with colors - highlight then copy only the cells in green: Attachment 136581)
    Oct 2022
    NEW CASTLE DE
    30
    Thanks fellas. I'll give it a shot when they arrive.
    14,071
    Not to be technical here but there is a big difference between it acting like it running out of fuel and it actually running out of fuel.
    There is no guess work in this. Hopefully you are using a wideband oxygen sensor to tune the MAF and VE tables so that fueling is correct.
    Tuning Addict
    10,887
    Glad I went to the trouble of making that .xls with all the converted data... every time I post it it never seems to get downloaded. Am I doing a bad job of describing what's in it?
    In case that's it, it is a spreadsheet with data for the common Gen 4 GM injectors - 19421333, 12587269, 12594512, 12613411, 12576341,12609749, 12613412, & 12598646 - converted into Gen 3 format. Tables Injector Flow Rate, Min PW, Offset vs Volts vs VAC, & Short Pulse Adder. Includes tables in returnless and referenced return-style formats. Copy and paste.
    Oct 2022
    NEW CASTLE DE
    30
    The person who did my remote tune, saw on the table he set up that the injector fuel flow was maxed out. The tune is in Speed Density.
    SoCal
    1,851
    Oh no!!! $420 https://www.glennsautoperformance.co...fuel-injectors
    Ebay new $60 including shipping
    I only needed to download your data twice. Once with you original data that worked perfect. Next was your revised data that worked perfecterr....
    Have done no less than a dozen of these now without a hitch. Still have another three sets on standby in the toolbox in case he sells out.
    Tuning Addict
    10,887
    $52/ea is $10 more than what you'd pay over the counter at the GM dealership. Jesus.
    edit: And a few months ago the dealer price was as low as $35/ea.
    Oct 2022
    NEW CASTLE DE
    30
    I absolutey didn't pay $420. I paid $139.99
    Oct 2022
    NEW CASTLE DE
    30
    Your spreadsheet shows flowrate vs pressure. In my file in HP Tuners it's listed as flowrate vs kpa. Is this the correct measurement to paste your info to?
    Banned
    Mar 2022
    Indiana
    4,289
    He's gonna need burped after all this spoon feeding.
    Tuning Addict
    10,887
    Oct 2022
    NEW CASTLE DE
    30
    Simply didn't see it SiriusC1024. No need for the bullshit comments.
    Aug 2020
    Thank you blindsquirrel for the hard work in creating this spreadsheet! I was lucky to snag some 12594512 flex injectors when I was taking the intake manifold from an LC9 at the junkyard and this will make it so easy for me to import the data into my P59. You are the MAN! I need to buy you a beer or 20.
    SoCal
    1,851
    Quote Originally Posted by timbro.slice View Post
    His injector data and the link to the ebay guy has saved me thousands of $$$ over the last year or so.
    Jan 2024
    19
    I am very new to using HP and have started to build a tune for my new engine set up. I was able to download the injector data and move it over to my tune without a problem. Thank you for having that info available to us, it made that part of the tune very easy!!
    2000 Sierra
    Jan 2024
    19
    But, I gotta ask cause I don't know. What is the difference between the new version and the old version of your data? Cause I moved over the data from the old version I beleive from the thread about "injector repository".
    2000 Sierra
