Yes...I will probably drop this one this week and wipe my hands and call it good. There are a few features I would like to try to add in to prevent those saddle shapes for missing data (just so this is a little more usable to those not as proficient with VVE stuff). Then the real work will begin on version 2.0!
My Tuning Software:
MAF Assistant
EOIT Assistant
I was watching the VVE video and it shows that the boundaries need set up. I have the speed density 2bar OS patch installed. Would I still be able to use the VVE tool?
the proper VE table is easy just get the error data as normal and adjust it, the VE dosnt have to calculate to anything alse it just stays as its adjusted cell by cell
Ah ok. So, no need to use the tool. Just have to make sure to plot against dynamic instead of the fuel trims. Thank you!
even easier its just wideband or trims error against the VE map/rpm table and ur done
My Tuning Software:
MAF Assistant
EOIT Assistant
L99 A6 - DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, IR EGM-205 Oil Pan Baffle, CAI Intake, Fast LSXR Intake Manifold, Nick Williams 103 TB, ZL1 Pump, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter
My Tuning Software:
MAF Assistant
EOIT Assistant
The issue is not in the the tune or in the editor.
The issue is an inherent defect in the HPT scanner (or maybe a limit of the CANBus or ECM itself, but probably HPT, IDK). Either way, the scanner is unable to report airflows above these numbers. And since these numbers are absolutely critical to the Dynamic Air formula, it renders this method helpless above these caps. Check this post's attachment... you can see the MAF and VVE values climb and then they flat line when they hit the built in limit in the scanner.
https://forum.hptuners.com/showthrea...l=1#post743605
My Tuning Software:
MAF Assistant
EOIT Assistant
As i started this process i had the virtual flex on. Felt better at the 14.3 afr, set to the factory 14.7 with Flex fuel off. Now performance seems to have gone away as i use these math's. Pedal response has gotten worse. Should i have it in force MAF mode? normal driving mode? My vve has gone pretty flat and one peaky area. LTFT lean 14-16% at idle. STFT don't indicate a vac leak issue. Also currently have DFCO off when i was following GRG's method. Comparing to my afr on bank 1 i'm lean.
What am i doing wrong?
2k11 Hoe TUNED 11-10 WB-14.68-1.hpt
11.10.hpl
I am not surprised with your drivability results.
I see three major issues:
1) The first issue is the most common issue I see, you are not logging the Fuel Trim Cell PID in your channel list, which is required for the filters, at least as how I use the filters.
2) You have a variable camshaft enabled and you are not logging the camshaft angle. You will need to log this and then add the filter for the cam angle = 0 to tune in "basic" mode (to use the VVE Assistant program I wrote). Then once that is set up you can move to advanced mode to work on when the cam is not parked.
3) Your high octane spark table...needs work
Additionally, I removed the large spike anomaly from your VVE in the idle area so I could get a read on the rest of the VVE. It is NOT smooth at all (see screenshot). Sounds like your VVE is a work in progress, but you goal is to smooth it out. Have you watched the VVE videos and used my tool (check my sig, you will need to watch both videos in order). No need to disable MAF, these formulas work in hybrid mode to tune both air flow models.
Keep at it, and you will get where you need to be!
Edit: I would recommend never using virtual flex fuel, especially if any engine modifications have been made. It is sketchy at best on a OEM fitted vehicle.
My Tuning Software:
MAF Assistant
EOIT Assistant
