Results 1 to 20 of 29
Thread: More issues on 2015 Z06
    Sep 2023
    11
    Hi all,
    Made a post on here a few days ago about some issues with how my new to me 2015 Z06 has been running
    https://forum.hptuners.com/showthrea...5-Corvette-Z06
    I've taken some more data logs and unfortunately seem to have discovered even worse issues than anticipated. Misfires on all cylinders but noticeably more on low rpm/cruising than WOT which I find strange.
    Prior to this discovery we (friend and I) believed it to be a single cylinder giving issues and may be tied to a bad injector, now with it being all cylinders while also seemingly running OKish (no catastrophic failure or inability to start) it led us to check out the spark plugs again. We found that the previous owner installed "NGK LTR7IX-11" plugs which I believe are aftermarket plugs that are 2 steps colder and is likely the reason all 8 cylinders are reporting misfires as well as why the car has a very long crank before turning over. What do you guys think? Can someone verify that the plugs currently installed are incorrect at least for how the car is currently setup and let me know the part number for the correct OEM plugs. I plan to make the change this weekend to hopefully clear up the issues I'm seeing if this is the case. Thank you all for the help!
    Tuning Addict
    7,172
    Timing is right at peak for optimal conditions at that boost. I would probably pull 2 or 3 degrees as I'm sure fueling wasn't dialed in to stay the same all the time - in fact I know it wasn't. If it had been and had more safeties still for temps and whatnot then that timing wouldn't be a huge no no. I don't like to run them that lean on gas. I know a lot out there do. Just not me... I run them there on alcohol, but still .8 on gas.
    Fueling changes a lot bank to bank. That could easily be the torque model being wrong as the torque model will completely change the fueling or cylinder 1's misfire. Cyl 1 appears to miss the most. While you have the plugs out just do a quick compression check. I think you'll be OK, but who knows for sure until it's checked. Could easily just need plugs and wires. Common enough on these.
    ~Greg Huggins~
    Sep 2023
    11
    Previous owner changed the plugs and wires 2k miles ago (stating oem plugs and wires) I think what I?m suspecting is he put in the wrong plugs. Are you able to confirm this? I just can?t see true oem plugs needing to be replaced a mere 6 months after installation with minimal mileage.
    Also I?m pretty new to tuning, only found this page as a friend ran the data logs for me and got me setup on this page to troubleshoot. With the issues I?m seeing, would putting correct plugs in (assuming these are wrong ones) correct it? Thanks for the input! Let me know what you think.
    May 2003
    South FL
    1,587
    The LTR7IX plugs are only 1 step colder and is the right plug if you have added a pulley and headers to the car. Otherwise the 6's are the stock heat range for the LT4. The 5's are for the LT1 only, if you put 5's in the LT4 you will have issues.
    If the previous owner installed plugs and wires, I would start to doubt the wires themselves. They are easily damaged if removed incorrectly. You could get some LTR6's and MSD wires for the car and start there. There is a chance the plugs are fouled as the LTR7's need WOT runs every so often to stay clean.
    TLDR, install new plugs and MSD (or OEM) wires and ensure the plugs are gapped properly and the wires are clicked on the plugs and the coils. It's a single click onto the plug side and a double mini click on the coil side. If you don't hear/feel this, then the wires are not installed properly.
    Another thing to check is pop off the valve covers and inspect the valvetrain. And lastly, make sure your O2's are switching back and forth when warmed up. I've seen bad O2 sensors cause fuel trims to go rich on one bank and foul all of the plugs and start misfiring.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    Sep 2023
    11
    Thanks for the info! The car has a 15% lower but stock manifold, it?s also street driven so not many opportunities to go WOT to clean them. I ordered a set of OEM plugs and wires (ACDelco 41-128 Iridium Spark Plug) and will check the gap (stated they are pre gapped to 0.030 but will verify) I?m assuming these are equivalent to the 6?s you mentioned. Either way I think I?m starting to narrow down the issue, I appreciate the help!
    May 2003
    South FL
    1,587
    Yes, the stock heat range is equivalent to the LTR6IX.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    I have been running the same set of LTR7ix in my Whipple SS since 2019 with no issues. I doubt the plug heat range is the issue.
    Aug 2020
    Petersham, MA
    146
    Quote Originally Posted by 1scls1z View Post
    It?s not.
    But if the plugs aren’t gapped right, got dropped during install, etc then they could still be a problem. But heat range is spot on.
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ ; 9.10 @ 153
    Quote Originally Posted by Joshinator99 View Post
    But if the plugs aren?t gapped right, got dropped during install, etc then they could still be a problem. But heat range is spot on.
    Definitely...but I thought that was a given.
    Aug 2020
    Petersham, MA
    146
    Figured I’d mention it since the OP is not the guy who installed the plugs. Anytime you have to make assumptions about someone else’s work lol…
    Sep 2023
    11
    Yeah, mistake on my part lol.
    Sep 2023
    11
    But also, why don?t we think the heat range is the issue. All signs point towards that being the problem? Long crank at cold start, misfires on idle and low rpm cruising but less at WOT, excess carbon build up with minimal mileage, misfires on all 8 cylinders and not any specific cylinder. Colder plugs as far as I?m aware would cause all of those issues alone, unless I?m missing something here. Let me know, I?m newer to this type of stuff so any educating is appreciated.
    Tuning Addict
    10,887
    All heat range plugs are the same temperature on a cold start.
    5BA8
    5,402
    Quote Originally Posted by ShawnC7 View Post
    None of that stuff would apply to a 1 step colder projected tip plug. Even a non-projected tip plug even 2 steps colder won't be a drastic difference in any of those things. They do end up looking darker over a short time but I wouldn't say excess carbon.
    I run non-projected tip plugs in pretty much anything FI especially if it makes any boost. A real cold non-projected tip plug on cold mornings will start rougher and run a little rougher than a projected tip plug will for maybe a minute. As soon as it gets the smallest bit of heat in it they come around.
    Sounds to me by your description the motor might have some damage.
    email=[email protected]
    Sep 2023
    11
    Maaaaaaannnn, well I guess I?ll see what happens this weekend when I install the oem plugs. I was really hoping this was gonna fix the problem.
    What confuses me is how the misfires go away after going WOT. Wouldn?t the misfires get worse if there were motor damage? I guess I?m just being optimistic here, I?m sure there?s other issues I?ve yet to diagnose.
    5BA8
    5,402
    I agree that is a strange scenario. I haven't looked at any of your data logs, but are you able to log the misfires? Can you feel them or are you looking at misfire counters on your scanner?
    By far (95+%), the most common causes of misfires in an LS or LT engine are cracked plugs and plug wires not snapped on all the way on either the coil or plug. If there's any doubt, replace all the plugs, and when you snap the wires on, you should feel and even hear a solid click on the plug and most of the time a double "click click" on the coil.
    Use an insulated spark plug socket. Take care not to over tighten them. A tapered seat plug only requires 15-18 ft lbs. It just needs to be snug. Spark plugs with compression gaskets are different. If you hear an audible "snap" when tightening your plugs, you just cracked the porcelain.
    5BA8
    5,402
    OK, going back and reading your original post, my best advice would be to do an accurate compression and leakdown test. I have a very specific way I want both done. I do a lot of email tuning for other shops and I have them follow my exact procedures for compression and leakdown testing.
    Then, in addition to that, I have them pull the plugs, take a piece of cardboard and poke 8 holes, 2 sets of 4, stick the plugs in the holes and with a sharpy number them on the cardboard. Then take close up pics for me.
    That's step 1 and 2. That's going to tell you a lot. I also highly recommend everyone who does this even as a hobby, own a borescope. They're cheap and readily available now.
    Step 3 is do a bore scope inspection. Using a cheap USB bore scope, readily available on Amazon, you take pics of the top of the pistons and even the cylinder walls.
    I've had a bore scope for probably 15 years now. They were expensive back then. And kinda crappy even for good ones.
    This is the one I have now. It's an articulating bore scope that uses your phone for the screen. It's an amazing tool. You can stick in in a spark plug hole and look all around. If you twist it just right you can look back up at the valves.
    https://www.amazon.com/Inspection-Ar...hlbWF0aWM&th=1
    Following all of these steps will tell you exactly what the mechanical health of your engine is.
    Figured I?d mention it since the OP is not the guy who installed the plugs. Anytime you have to make assumptions about someone else?s work lol?
    Valid point!
    Sep 2023
    11
    Unfortunately read this after doing all of the work.
    Just finished swapping out the plugs and wires and data logging. The original plugs were gapped properly, all had carbon build up, at least 2 were fouled with oil.
    Ran a compression and leak down test on all 8 cylinders. All cylinders held pressure at 225-230psi, no outliers no leaks.
    Data logging showed the bad news. Still misfires on all 8 cylinders. Couldn?t determine if it was less than before, still had a dozen or more misfires in a 10 minute drive. Still seeing less to no misfires on WOT than idle/cruising speed.
    The mechanic/knowledgable fellow who was helping me out looked over the tune and said with it being misfires on all 8 cylinders it?s likely the tune, and the timing is way too high. He recommended bringing it to a new tuner and having it retuned from the ground up and knock the timing back a few notches.
    Tuning Addict
    10,887
    This needs someone competent who can go hands-on with this car. Further tuning won't fix it if it's been hurt from a previous bad tune.
