Results 1 to 14 of 14
Thread: Ignition Timing and Nitrous Oxide
    Oct 2019
    ATL
    57
    I have begun contemplating the addition of Nitrous Oxide to my engine for drag racing. (BGE block with forged stroker crank, rods and pistons and 9.5:1 compression)
    Is there a way to set up a tune so that when nitrous is activated, the appropriate amount of timing is pulled, but equally, if nitrous is not activated, ignition timing remains unchanged?
    Or is it a proposition where if you don't activate the nitrous, you have to live with retarded timing that would support nitrous if it was activiated?
    Thanks for any insight.
    rich
    Jan 2022
    972
    convert it to corn
    tune it for your 9.5 to one/cam combination
    leave the timing where ever it ends up
    and squeeze the snot outta it
    how big of a motor, why 9.5, and what cam did you pick for that?
    how big of a unit are you thinking?
    5BA8
    3,604
    How big of a shot, that should be the first question.
    For the most part, you'll never notice the missing HP with the timing pulled for N2O when you're not spraying.
    email=[email protected]
    Jan 2022
    972
    9.5 to 1
    i am picturing 430-440 inches
    leave on a 200 shot and ramp in an additional 250?
    Aug 2021
    Yorktown VA
    203
    Leave on a 200 shot? Might want to edit that post to swap out "Leave" for "Launch", and to put in a big, fat "Attempt at your own Risk" disclaimer in there along with it. But in any event, this suggestion has certainly caught my attention. And assuming Rich s or I wanted to run a shot combo like this, how would you suggest tuning the fueling to be able to leave on a 200 shot?
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
    Oct 2019
    ATL
    57
    pistons available were 9.5:1 and 12.x:1. My builder (Jeff Taylor) said go with 9.5:1 as the engine is supercharged.
    The displacement is 426
    The cam is the Comp Cams Supercharger Stage 2 cam. 235deg @.050 lift, .625 lift.
    Oct 2019
    ATL
    57
    150 shot
    Jan 2022
    972
    that is barely over 10% of what the motor makes
    build a dry shot and write a tune for it
    it will be a lil fat when not squeezing - no biggie
    Jan 2022
    972
    Quote Originally Posted by Spray-Cam Hell-Ram View Post
    what are you trying to say?
    have thrown what equals a lot more than that at a 100 cu in 4 cyl suzuki motor
    with great success i might add : )
    set it up so both fuel solenoids are wide open at the hit
    the small unit's nitrous solenoid is open as well
    ramp in the big nitrous solenoid with a controller
    5BA8
    3,604
    Quote Originally Posted by rich s View Post
    Sounds like Jeff Taylor is the guy you'd need to talk to. I know if you were thinking about spraying 150 shot on my supercharged engine that I built for you, I would want to know.
    Jul 2017
    33
    So I have run between 100-200 on a hellcat engine at 18lbs. Forged rods and pistons and OfCourse better valve springs and push rods. That combo was 8.20-8.50 1/4 mile in my 3500lb drag car. Over 300 passes (not all nitrous) with no issues at all and now after a refresh of rings and bearings that engine is in my daily hellcat that now runs a best of 9.19 on a 125 shot.
    I don't ever switched tunes as its not worth the gain to me. That is Unless I cross the 150shot barrier. I run no NOS and up to 150 all on the same tune. Never an issue. Could it run slightly better off the bottle with more timing? probably but it still runs 9.50-.9.70 depending on weather so I am good with that.
    Jan 2022
    972
    1) that is your ego : (
    2) that is job security : )
    i have two nitrous pro mods in my trailer that i tune. a 150 shot on a 420+ inch motor is next to nothing. i build nitrous systems and nitrous fuel systems. lemme know if you want help.
    Aug 2021
    Yorktown VA
    203
    There was no underlying meaning there in my post. The comment about adding a disclaimer when telling someone to squeeze a 200 shot off the line was suggested only because doing so would be going directly against what everyone of the nitrous manufacturers tell you to absolutely never do in all of their install instructions pdf downloads. And while I'm sure you'll be able to tell me why doing so would be just fine, but because this about what he should do on his build and not your own, hence why and only why I made the "add a disclaimer" suggestion. That being said, the rest of the post was quite literal and genuine. I myself have just very recently gotten to the point where I feel comfortable enough to make my own nitrous set-up active and unlike yourself, Im quite inexperienced in this particular area. Im also in the process of converting over to E85 and am trying to decide exactly what kind of shot would be optimal for my current build/set-up when having a shot capability that ranges between 100-400 shot from my nitrous express Holley Hi-Ram nitrous plate kit. Im running a 6.5L stroker (396) with a lil over 12 to 1 compression, fully forged of course, and as a starting point I have to assume that my range will likely be quite a bit less than the shot amount available due to my compression. However, I do have a Maximizer 4.5 second progressive controller to start incorporated in my nitrous set-up, as well as their electronic rpm window switch. My initial thought was to run maybe a 200 shot over a 4 second progression once hitting around 3600-3800 rpm on a 1/4-mile pass. I was actually unaware that squeezing a shot right off the line was even an option to be honest. Which is why I had asked you in my post how would you tune your fueling for something like that. Because if there is a way to safely run a shot right out of the gate as well during a pass, then I think that that initial shot off the line would be the biggest benefit of all with running nitrous. I was legit asking you how this could be tuned for and done.
    Jan 2022
    972
    that whole "nitrous dont like compression" thing died when companies figured out how to make fuel bout 30 years ago
    whats it leave like now with the 3600?
    lets see a log
    2016...
    it has a hp75 in it?
