Page 4 of 4 FirstFirst 1234
Results 61 to 64 of 64
Thread: Default C6 MAF and Schematics and diagnostics
  1. #61
    Oct 2023
    29
    Seems like all my engine block grounds had poor path to ground. Adding a large gauge wire to my chassis (around the firewall and under the header) seems to have fixed it. Wonder what the root cause is?
  2. #62
    2,876
    Sounds like root cause is a bad ground? You can't get more root cause than that.
  3. #63
    Oct 2023
    29
    Sure, but it's a factory ground. Just wondering what might be causing the poor path to ground if there are 3 factory ground points on the aluminum engine block.
  4. #64
    2,876
    Either the connections are bad/dirty/corroded, wire is corroded/broken or missing a wire.
