Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 102
Thread: Failed MAF = Intermittent Stumble
    North Carolina
    4,859
    Quote Originally Posted by verlon View Post
    Exactly! And you've caught far more precious thing
    Attachment 140121
    Thanks, Cringer.
    that is it.
    You can zoom in on the VVE table by changing axis's and not find a blip like that.
    North Carolina
    4,859
    Quote Originally Posted by squeeler642 View Post
    Here's my issue, in a screenshot and attached log. Seems like the exact same symptom. Thoughts on how this would happen on a Gen III truck?
    loose ground or something along those lines is usually the cause.
    F bodys would do this a lot when guys wouldn't put the battery tie down back in and let the battery rock into the fender.
    Tuning Addict
    7,172
    I am curious to know what you can find, although I am not sure there is going to be any real fix we can do with HPT.
    If Verlon can find the root cause in the coding and it's not in the hard coding then you might be surprised
    ~Greg Huggins~
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,131
    What I am saying is, my guess is that there is a defect in the code. No way to update the algorithm.
    My hope is there may be work arounds relating to manipulating some of these values:
    • Prediction Coefficients
    • MAP Filter and Sampling Coefficients
    • [ECM] 3034 - Spark Airmass Blend
    • [ECM] 13426 - VE Initial Correction Factor
    • [ECM] 12003 - Intake Manifold Volume
    These are all a shot in the dark...hoping Verlon can find the smoking gun!
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Just passing on some info that seems to have fixed the issue for me.
    I've been getting the same 'VVE Bug' problems. 2200rpm and below, everything drops - fuel, airmass etc. Have had some cutouts at 5200rpm too, everything drops and recovers.
    I'm OL SD, E67 LSA.
    I've had tune iterations with, DynAir enable/disable maxxed - random/occassional stumbles, not too bad. DynAir enable/disable down at 400rpm, still SD - stumbles much worse, very regular when 2200rpm and below.
    After seeing the thread in attached pic, I checked my AirCalc state when the stumbles occur. Stumbles only seem to happen after I've gone over 4000rpm. If I drive for an hour and don't go over 4000rpm - no stumbles. Once I go over 4000rpm, stumbles come in and also transients go to shit.
    This coincides with going from AirCalc state - Normal, to HiSpeed, and then getting stuck in NormalTrns for the rest of the drive.
    Anyway, I've since put my DynAir enable/disable back to stock, and applied the Speed Density Air Mode patch.
    Now I can go over 4000rpm, and my AirCalc will go straight back to Normal after HiSpeed. No stumbles so far and fueling tracks much smoother. Transients stay the same throughout the drive too (before was big lean spikes when stuck in NormalTrns).
    2017 HSV Clubsport R8 LSA 30th Anniversary M6 - GMM triple-step headers, Cat delete, Stock HSV catback, Harrop pod intake, ID1050X injectors, KB BAP, 2.35" Griptec pulley w/ Gates RPM belt, FII blower & lid spacers, FII reservoir, Mantic 9000 ceramic clutch, Elite Eng. catch can, AEM 30-0334 wideband
  6. #26
    Aug 2021
    1,131
    Quote Originally Posted by L1FTD View Post
    I'm OL SD, E67 LSA.
    Wow this is very informative! Thank you for posting this info. I seemed to notice a correlation after going WOT, but not specifically 4,000 rpms.
    Verlon has been working hard behind the scenes here and created a custom patched OS. I have not had a chance to test it...but his solution is different than HPT's though.
    MAF Assistant
    EOIT Assistant
  7. #27
    Ok, great stuff!
    I noticed in your screenshots of the stumble, you were in that same ?NormalTrns? AirCalc too.
    Putting my DynAir disable back to stock did not fix the AirCalc, but the air mode patch did.
    It might not be exactly 4000rpm, but somewhere close. Whatever the rpm the switch between ?Normal? and ?HiSpeed?. Once I hit ?HiSpeed?, I would never get back to ?Normal? after. Only ?NormalTrns? or ?HiSpeed? again.
    Also, did not matter that I had DynAir disable maxed at one point. AirCalc would still change to ?HiSpeed? (i.e. MAF only mode). Interestingly, putting DynAir disable down at 400rpm, I would be in ?HiSpeed? all the time, and that made things worse.
    Anyway, will keep following
  8. #28
    Oct 2014
    Moscow, Russia
    320
    That's awful, but yes, there is another bug in the AirCalc Mode state machine. It can get stuck in some state if DynAir Enable/Disable thresholds pair is lower than fuel Fast/Slow thresholds pair.
  9. #29
    Banned
    Mar 2022
    Indiana
    4,289
    Where are the Fast/Slow fuel settings?
    Is this it?
  10. #30
    That's awful, but yes, there is another bug in the AirCalc Mode state machine. It can get stuck in some state if DynAir Enable/Disable thresholds pair is lower than fuel Fast/Slow thresholds pair. Being stuck in this state has terrible consequences - engine speed variable, used for all DynAir calculations (inc. VE), freezes at the moment of stepping into this state.
    HPT patch does not solves this bug.
    Interesting!
    Are the fuel fast/slow thresholds accessible in HPT?
    I assume this would be irrelevant if the DynAir thresholds are left stock.
    Occasionally at high rpm (usually around 5200) I would get a cut. Fuel drops to zero, airmass zero, MAT zero. Recovers almost instantly, but obviously very concerning.
    Thinking back, these high rpm cuts only started happening when I unnecessarily maxed the DynAir thresholds. MAF is de-pinned, so I had no need to change the DynAir.
    Since the AirCalc patch and DynAir back to stock, I am still yet to have a low rpm stumble or high rpm cut. Hoping I had two separate problems, with two separate fixes applied. Will see if it lasts.
    Moral of the story for me - only change what is necessary, leave stock where possible Too many hidden tables
  11. #31
    Aug 2021
    1,131
    Is this it?
    Here is the explanation on those fields:
    https://forum.hptuners.com/showthrea...l=1#post719020
    MAF Assistant
    EOIT Assistant
  12. #32
    Oct 2014
    Moscow, Russia
    320
    Is this it?
    No, that's closed loop timing.
    Fuel timing is different and not defined in HPT as Chris stated.
  13. #33
    North Carolina
    4,859
    Awesome. It would be nice to have a fix. There are several platforms that do not have the 2 bar OS available. A fix is definitely needed.
  14. #34
    Banned
    Mar 2022
    Indiana
    4,289
    I take it you can see it, though. Are you able to define for us a no-go range of DynAir filtered MAF enables to prevent this phenomenon?
  15. #35
    Banned
    Mar 2022
    Indiana
    4,289
    Good info thanks for the link.
  16. #36
    Tuning Addict
    7,172
    Verlon's already got a patch he's testing to my knowledge. Great to know he found it and it can be fixed.
    Verlon, will these be available via xdf's? Or is a complete code patch rework required? Can we kill the baro update too?
    As always, Thank You Verlon!!!
    ~Greg Huggins~
  17. #37
    Oct 2014
    Moscow, Russia
    320
    On L94 DynAir Enable/Disable matches fuel thresholds (3900/4000).
    VE Patch is tested. I'm preparing detailed description of the VE bug and what exactly patch does.
    AirCalc Mode patch will take some time.
    HPT does not allow modifying OS via xdf and they are right, it is an easy way to brick ECM.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
  18. #38
    Aug 2021
    1,131
    Yes, I did verify Verlon's patch worked today — it prevents the fueling spike. However, the "AirCalc Mode" getting stuck in "Normal Trns" pointed out by L1FTD is still an issue. As to what impact this actually has, I do not know. I think Verlon may be working to address that to, but that is his call.
    The other crazy part is that applying this patch solved some moderate idle surging that was occurring after installing a 103mm throttlebody. So major kudos to Verlon on his work on this!
    MAF Assistant
    EOIT Assistant
  19. #39
    Tuning Addict
    7,172
    Maybe I should have worded differently instead of grouping everything together. Will the rpm settings be available via xdf and do they just need to be the same as the dyn settings? Added the last part but it just came up as another possible question
  20. #40
    Here are some screenshots of the NormalTrns issue.
    First three are what was happening for a long time. First part of drive before going over 3800-4000rpm = Normal, then to HiSpeed, then stuck in NormalTrns.
    Second three are after the HPT SD air mode patch. Normal, then HiSpeed, then back to Normal - no NormalTrns again.
    Before Air Patch - Normal.pngBefore Air Patch - HiSpeed.pngBefore Air Patch - NormalTrns.png
    After Air Patch - Normal.pngAfter Air Patch - HiSpeed.pngAfter Air Patch - Normal Again.png
