Results 1 to 9 of 9
Thread: Can someone take a look at my injector rescales?
    Jan 2021
    6
    Hi Everyone, New here
    But i have a question, and going to be using FIC 130Lbs/Hr injectors on a E38 ECU. i trying to use FIC's Data sheet, but when i copy and paste values after 388kpa's the values look maxed out at 127lbs/hr. even though the file from FIC keeps increasing values to 153lbs/hr.
    Any and all help is appreciated.
    i have attached a excel file with Stock, FIC's data, and what the values look like after copying and pasting values.
    Is this something normal or do i have to change any values?
    Thanks in advanced, for any and all help.
    Tuner Alex14SS's Avatar
    Aug 2021
    Florida
    92
    Post your stock tune
    8,096
    Half half double. Easy. Half the actual injector flow rate, then half (x .5) the entire IVT Terms: AFR Term table, then double Stoich (x 2). Do not reinvent the wheel here.
    8,096
    I am still waiting for someone to release the browser plugin that will decode 'FIC' and tell whether that's supposed to mean Fuel Injector Clinic or Fuel Injector Connection. No luck so far.
    Jan 2021
    6
    Quote Originally Posted by Alex14SS View Post
    Jan 2021
    6
    Sorry, Yes
    Jan 2021
    6
    And here's the Original Stock tune the truck came with.
    8,096
    The FIClinic spreadsheets have a built-in scaling function.
    Make sure to pick the correct line that matches your ECM, then just copy-paste. And half/double those other two tables.
    Aug 2021
    910
    LOL HPT should apply a filter to forum posting that populates the 2 choices in check boxes whenever FIC is detected.
