Results 1 to 10 of 10
Thread: Dakota Digital, AEM wideband, data logging
    Dec 2006
    Pensacola, FL
    496
    I recently swapped and L86/8L90 into a 84 C10. The motor and tranny are running and I'm trying to finish up wiring my Dakota Digital gauges. I purchased their AFR BIM module (13-2) dakotadigital.com/pdf/BIM-13-2.pdf and purchased an AEM inline wideband 30-0310 30-0310 X-Series UEGO Inline (menlosecurity.com). The DD BIM uses a 0-5 serial input and I have that wired and working correctly. My question is how can I data-log using the MPVI3 with ProLink+ while still having my gauges connected? Can I piggyback off of the 5V input into the DD module (white wire)? Or can I use the AEMnet CAN HI/LO wires to connect to the ProLink+? Thanks in advance!
    Tuning Addict
    6,902
    I've never been able to log with the gauges plugged in. They always interfere with the scanner being able to log correctly. I just use my cell with a gps app to get a rough speedo reading while I'm logging.
    ~Greg Huggins~
    Dec 2006
    Pensacola, FL
    496
    Hey GH, thanks for the quick reply and you are absolutely correct about the gauges interfering with the scanner, its no bueno! I really did a poor job asking my question in effort to provide all the pertinent info, LOL. What I'm trying to figure out is this, Can I hardwire the AEM +5v serial output to my DD 13-2 AFR BIM, and at the same time wire the AEM CANBUS signal wires to the HPT ProLink +, unplug my DD gauges from the OBDII port, plug in my MPVI3. Will I get a correct AFR signal on my scanner? A lot of words for a simple question LOL. Rob
    Tuning Addict
    6,902
    If you have the obd2 Aem then unplug the d d and plug the other 2 in like normal. If you don't then use the pro link like you're talking about.
    Dec 2005
    604
    The 0-5v output and CAN interfaces are fully independent, on the AEM widebands. So, you can rout CAN to 1 device, and 0-5v to another. Just don't forget the brown wire
    Dec 2006
    Pensacola, FL
    496
    Thanks GH, I plan on using the CanBus signal on the ProLink.
    Quote Originally Posted by dr.mike View Post
    Do I even need to use the brown wire DR.MIKE? I plan on using the AEM CANBUS signal for the ProLink+ and the Dakota Digital module only requires a one wire 0-5V+ input (directions are in the link above). Am I missing something?
    Also which "output type" should I use for the BIM setting? Thanks for the help!
    EDIT: In order for the DD module to work, both the brown and white wire have to be use from the 30-0310 harness (thanks Dr. Mike!)
    SoCal
    1,624
    Quote Originally Posted by HartRod View Post
    Do I even need to use the brown wire DR.MIKE? I plan on using the AEM CANBUS signal for the ProLink and the Dakota Digital module only requires a one wire 0-5V+ input (directions are in the link above). Am I missing something?
    Brown wire is the ground wire for the 0-5 volt ANALOG output. It is not a "data" line AEM or CANbus. AEM and CAN are two separate forms of communication and should not be mixed. HP Tuners can use the AEMnet or the CAN if you have a Part # 30-0334 and of course the analog 0-5 volt output that can be used on Pro Link or on the EGR wiring if the ECM/PCM has that as an option/OS
    Dec 2006
    Pensacola, FL
    496
    I have the AEM 30-0310. I'm using the AEMnet HI/LO wires to connect to the CANbus HI/LO wires on the ProLink+. I'm using the white wire and brown wire out of the AEM sensor harness to provide the input into the DD AFR module. Sorry if I wasn't clear before.
    Dec 2006
    Pensacola, FL
    496
    dr.mike you were correct! I had to connect the white AND brown wire to the Dakota Digital BIM box in order for the AFR to display on my DD RTX gauges correctly, THANKS! Now I am trying to log/display AFR on my scanner using the MPVI3 with the ProLink+. I have connected the AEMNet CAN high wire (black/white) to the ProLink CAN high wire (orange) and the AEMnet CAN low wire (green/white) to the ProLink CAN low wire (yellow). I repolled the scanner, added the AEM X series UEGO WB EQ ratio 1 PID. However, when I start scanning, nothing populates in the PID. Thoughts? TIA.
    I'm not sure if this matters, but my swap is a GEN V E92/T87 using a Speartech wiring harness.
    Dec 2006
    Pensacola, FL
    496
    TheMechanic - I have a 30-0310 and it say it has outputs for the AEMnet which I have connected to my Prolink+/MPVI3. However, I'm not getting anything on the scanner. Any thoughts as to why it's not working? As stated before, I swapped a 2017 L86/8L90 into an 84 C10 using a Speartech wiring harness, E92/T87 using a 2015 Corvette OS.
