Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 73
Thread: Help Tuning VVE / Start and run, but not idle
    Feb 2022
    Hoover, AL
    62
    Dude the table is horrible as it is. Nothing wrong with hitting the smooth button 20 times. You aren't going to make it any worse that's for sure.
    Here's the result after taking a stab at the VVE table. Car started and idled fine, still 10-12% rich at idle. I am now looking for the gen 4 idle guide...wondering if the idle airflow settings are keeping it rich.
    Attachment 145889
    5BA8
    5,576
    Quote Originally Posted by Loose_Screws View Post
    Attachment 145889
    Where is the data log that corresponds to that version?
    Need to hit smoothing about 15 more times.
    Idle airflow settings have nothing to do with how far off the trims are. That's dialing in the respective airflow tables. VVE and MAF.
    email=[email protected]
    Feb 2022
    Hoover, AL
    62
    Attachment 145892
    Feb 2022
    Hoover, AL
    62
    Attachment 145895
    Attachment 145896
    Last tune and log of idle. Table is smooth(er), still rich and making corrections of 13%.
    5BA8
    5,576
    Attachment 145895
    Attachment 145896
    Dude, you gotta dial it in. Smoothing it isn't dialing it in. "It's still rich" is a ridiculous statement to make at this point. Of course it's still rich. You haven't done anything to dial it in.
    Now go drive it and plot your trims, then apply the correction. It will take several iterations. You can't just make one change (smoothing) and expect it to be not "still rich".
  6. #26
    Feb 2022
    Hoover, AL
    62
    Made several iterations, seem to be making some progress. For lean cells, I was applying full percentage. For rich cells, if they weren't over 5% or so, I typically did not apply them and when I did I use 1/2%. It was also interesting to see that sometimes I could adjust one cell and multiple cells would change, almost like clicking calculate coefficients.
    As I sit having a cigar and thinking it over, I have been adjusting the MANIFOLD SWITCH CLOSED table. Should I be copying save values over to MANIFOLD SWITCH OPEN table...or does it matter?
    VVE table still needs work, but far from where it was.
    5.4 - Nova, fail MAF, Log LT and ST for VVE correction, pass13.hpt
    5.4.24 - Pass 13.hpl
    5.4 - Nova, fail MAF, Log LT and ST for VVE correction, pass14.hpt
    5.4.24 - Pass 14.hpl
    5.4 - Nova, fail MAF, Log LT and ST for VVE correction, pass15.hpt
    5.4.24 - Pass 15.hpl
    On "Pass15" tune, I added blanket 10% from 60kPa and up, 1200 RPM and up. Trying to richen it up in the lower table. Also, in the corresponding log I was hitting PE and it was not logging to histogram (filter running). And still have a little blip whenever I lightly press pedal at a dead stop. It's nearly as severe as it was prior to working on the tune. And the blip doesn't happen if I press the pedal a little more aggressively or if I am already rolling.
    Thanks for the help!
  7. #27
    Mar 2009
    Andover, MN
    829
    Make corrections to Manifold Open. Also make sure you are resetting the LTFT's after you make fueling adjustments.
  8. #28
    Feb 2022
    Hoover, AL
    62
    Quote Originally Posted by ns158sl View Post
    Ah...I have NOT been resetting LTFT's after adjusting VVE.
  9. #29
    Aug 2021
    1,142
    If you have the stock "as found" file, id put the timing tables back to stock along with the BRAF table and start over. You're idle timing is 25* and it averages 15*. Looks to me that the overspeed correction is constantly in play at idle. Too much BRAF and the ECM trying to use spark correction to limit rpm.
  10. #30
    Feb 2022
    Hoover, AL
    62
    Quote Originally Posted by LS ROB View Post
    I don't have an "as found", bought the ECM/TCM used. I'll copy over timing tables from a stock 2010 5.3 Silverado tune. Thanks for looking at the tune!
  11. #31
    Feb 2022
    Hoover, AL
    62
    So I have ran into the issue again where after loading a tune the car won't idle. Will crank/run fine and then IPW drops to 0.7. Any idea what is causing this to occur?
    5.4 - Nova, fail MAF, Log LT and ST for VVE correction, pass16, VVE only.hpt
    5.4.24 - Pass 16, VVE, won't idle.hpl
    EDIT: Seeing what LS Rob posted about timing...is it because timing is swinging so far the ECM limits fuel and therefore IPW drops to 0.7?
  12. #32
    Feb 2022
    Hoover, AL
    62
    Both snippets below are from same tune.
    The first snippet the timing doesn't swing, but IPW drops to .7 and engine dies.
    The second snippet the engine tries to run for a few seconds, IPW drops to .7 and engine dies.
  13. #33
    Aug 2021
    1,142
    Try this VVE test to see if it will idle.
    VVE test.hpt
  14. #34
    Feb 2022
    Hoover, AL
    62
    [QUOTE=LS ROB;779187]Try this VVE test to see if it will idle.
    Cranked and idled like a champ! The timing didn't fluctuate as much either.
    5.5.24 - Test VVE_From LS Rob.hpl
  15. #35
    Aug 2021
    1,142
    There's much more to do, but that should get you started. Its showing rich from that small log but after some driving, you should know more about where the trims will be and can apply the changes using the trims.
  16. #36
    Aug 2021
    1,142
    You also have a few codes that you may want to check out. I'm not familiar with the EVAP and P0010 codes. Clear them to see what comes back.
  17. #37
    Feb 2022
    Hoover, AL
    62
    The engine was stripped of EVAP and I have set all of those to no SES or MIL, but keeps coming back. The engine also has a fixed camshaft, have P0010 turned off as well. I try clearing the codes, but they come back.
  18. #38
    Aug 2021
    1,142
    Ahh ok. I looked and they are set NER. It may be something that we can't see using the newer version of HPT. Grab a log of around 20 min of driving if possible; lets see what that thing looks like.
  19. #39
    Feb 2022
    Hoover, AL
    62
    Here is a cruise log 5.5.24 - Test VVE_LS Rob, cruise.hpl
    I copied trims to tune, applying by 1/2. Smoothed and then calc coefficients. Loaded tune, cleared LT trims and back out for another drive to log.
    VVE test_from LS Rob, Pass1.hpt
  20. #40
    Aug 2021
    1,142
    Give this one a go. I checked on the one you attached and the looks like the VVE didn't change.
    VVE test-1.hpt
