Results 1 to 17 of 17
Thread: 2009 Silverado Truck Norris Start with Hanging Throttle
    Dec 2022
    8
    2009 Silverado LTZ, Truck Norris NSR, stock exhaust
    Wideband is not installed yet
    I followed Matt Stanfords video on Idle Startup Tune here as he gave specifics from his experience with the Truck Norris
    https://www.youtube.com/watch?v=1QIRgaGfzWk
    It starts and idles ok but I'm experiencing a couple of things that I need to get resolved before I feel comfortable driving it to get the wide band bung welded in. Once it gets warm, Stabilitrak warnings are set and the throttle hangs. Sometimes the throttle is just very slow on the return and sometimes it sticks at 2-3K RPM and holds.
    I've uploaded my stock tune (with DOD turned off), the current idle tune, and a log of the slow throttle. On the log, I couldn't get it to stick but you can certainly see the slow throttle return. Any advice is welcome as this is the first time I've worked on a LS with anything bigger than a Stage 1.
    2009 Silverado LTZ - Stock DOD Delete.hpt
    2009 Silverado LTZ - DOD Delete - Truck Norris 20240511 - Start.hpt
    20240513 Throttle Slow.hpl
    5BA8
    3,604
    BRAF is way too high for that cam.
    email=[email protected]
    Dec 2022
    8
    Do you have a suggestion for what is a more appropriate?
    Sep 2021
    Kentucky
    556
    See if this helps you out any.
    Dec 2022
    8
    I didn't have a chance to go through the tuning guide yesterday but I did try this tune this morning, Similar to the first the initial crank was VERY long but then it started and appeared to idle fine again. But, on throttle blips it was SLOW to return, then on the last blip it climbed and hung. I had to shut off the ignition.
    20240514 Throttle Hang.hpl
    5BA8
    3,604
    Put your BRAF ETC multiplier and your throttle follower back to stock. Data log and report back.
    2,981
    Yes.. do this or somewhere in between is likely where it will end up.. maybe compare the differences and multiply the DIFFERENCE by .5
    Tuner at PCMofnc.com
    Dec 2022
    8
    This seemed to help. I only had a minute to try it this morning and it atleast made it better when cold.
    5BA8
    3,604
    Now it looks pretty normal.
    Sep 2021
    Kentucky
    556
    You can try that throttle follower table and see how you like it. It only makes it less aggressive in gear. Wonder why the BRAF multiplier is so low on that os?
    Dec 2022
    8
    I didn?t get a chance to try this tonight but I will. I did try another cold start and the first start cranks for several seconds before it starts. After the initial start, the subsequent starts are quick. Is this likely a temperature/timing issue?
    Sep 2021
    Kentucky
    556
    After the maf and ve are dialed in i would think it should crank better. Im not sure what ect you are having long crank at but i made some adjustments at cooler temps. See if this is better or worse.
    5BA8
    3,604
    Alot of them have that same multiplier.
    5BA8
    3,604
    Quote Originally Posted by J_S_R View Post
    Could be too much fuel or not enough airflow or a combination of both. First thing to do is check the fuel pressure. Unless you know what it is you don't know if you're "tuning around" a mechanical problem or not. The fuel could be draining back.
    Sep 2021
    Kentucky
    556
    I also thought of fuel pressure issues. I think that would be a good idea to check pressure on the cold pump. I say dial in the fueling completely before any further tuning to correct any issues. Cant correct a bad airflow model with bandaids.
    Dec 2022
    8
    Fuel is a at 60psi cold. The latest file seemed to
    make it better.
